Plugin SDK
Breadcrumbs
event_trigger_format Method
Return the description for the given event trigger
Namespace: Scheduler Assembly: Scheduler (in Scheduler.dll) Version: 3.0.0.0 (4.0.0.12)
Syntax
C#
public static string event_trigger_format( int ref, int index, int groupindex)
VB
Public Shared Function event_trigger_format ( ref As Integer, index As Integer, groupindex As Integer) As String
Parameters
ref
Type: System.Int32
index
Type: System.Int32
groupindex
Type: System.Int32
Return Value
Type: StringString
See Also
functions Class
Scheduler Namespace
