Plugin SDK
HS4ZWAVE 4.0.1.0 Beta
Changes
This is a small update to fix an issue when including the HomeSeer DS100 and MS100 devices.
  • Fixed an issue when adding the DS100/MS100 and are using a 700 series Z-Wave interface
  • When adding a battery device, the battery level is updated immediately
If you are using Z-Seer you will need to update to version 3.0.0.41 or later.
Download:
https://homeseer.com/updates3/SetupZ-Seer_3_0_0_41.msi
