Plugin SDK
plugin_property_get Method
Access a property in a plugin
Namespace: Scheduler Assembly: Scheduler (in Scheduler.dll) Version: 3.0.0.0 (4.0.0.12)
NOTE: This call is deprecated and should not be used.
Syntax
C#
public static string plugin_property_get( string plugid, string prop, ScriptArray scrparms)
VB
Public Shared Function plugin_property_get ( plugid As String, prop As String, scrparms As ScriptArray) As String
Parameters
plugid
Type: System.String
prop
Type: System.String
scrparms
Type: ScriptArray
Return Value
Type: StringReturns the property value
See Also
functions Class
Scheduler Namespace
