This section contains information on scripting. |
This function returns the path to the directory that the last script was run from.
None.
Return value: path
Type: string
hs.WriteLog "Script Path", hs.GetScriptPath
Writes this (example) to the log:
4/1/2004 2:00:00 PM~!~Script Path~!~C:\Program Files\HomeSeer\scripts\
Or for a script run from the scripts\Includes directory:
4/1/2004 2:00:00 PM~!~Script Path~!~C:\Program Files\HomeSeer\scripts\Includes
This function indicates if a specified script is currently running.
Parameter: script name
Type: string
Description: This is the name of the script to check.
Return value: status
Type: boolean
Description: This returns TRUE if the specified script is currently running and FALSE if it doesn't.
' check if the script "weather.txt" is running
if hs.IsScriptRunning("weather.txt") then
hs.writelog "info","The weather script is still running"
end if
Public Function RunScript(ByVal scr As String, ByVal Wait As Boolean, ByVal SingleInstance As Boolean) As Object
This function runs another script. This will also return a value from the called script provided the "Main" procedure is a function. Scripts must be located in the scripts directory in the HomeSeer application directory (C:\Program Files\HomeSeer 2\Scripts by default).
Parameter: Script
Type: String
Description: This is the file name of the script to run. Do not include the path in the script name. The "Main" procedure in the script will be run. If you need to run a specific procedure other than Main, see RunScriptFunc .
Optional Parameter: Wait
Type: Boolean
Description: When set to TRUE, the script that is calling hs.RunScript will not continue processing commands until the script referenced here is finished. Set this to False to allow the script using hs.RunScript to continue processing commands after launching the additional script.
Optional Parameter: SingleInstance
Type: Boolean
Description: When set to TRUE, only one instance of the script referenced by hs.RunScript can be running at a time, so if there is one instance already running, calling this again will result in an empty/null return and an error message written to the log.
Return value: Value
Type: Object
Description: This returns any value that the called script returns from the Main function - Sub Main will not return any values.
Public Function RunScriptFunc(ByVal Script As String, ByVal Proc As String, _
ByVal Params As Object, ByVal Wait As Boolean, _
This procedure runs another script and specifies a procedure to run in that script and optional parameters. This will also return a value from the called script. Scripts must be located in the scripts directory in the HomeSeer application directory (C:\Program Files\HomeSeer 3\Scripts by default).
Parameter: Script
Type: String
Parameter: Proc
Type: String
Description: This is the name of the procedure (Sub or Function) to execute. If this is left blank, the procedure "Main" will be run.
Parameter: Params
Type: Object
Description: This is a parameter or a set of parameters to send to the procedure. This can be a string or numeric value, or even an array of different values.
Type: Boolean
Description: When set to TRUE, the script that is calling hs.RunScriptFunc will not continue processing commands until the script referenced here is finished. Set this to False to allow the script using hs.RunScriptFunc to continue as soon as the other script is launched.
Type: Boolean
Description: When set to TRUE, only one instance of the script referenced by hs.RunScriptFunc can be running at a time, so if there is one instance already running, calling this again will result in an empty/null return and an error message written to the log.
Return value: Value
Type: Object
Description: This returns any value (numeric, string, object) that the called script returns if the called procedure is a function.
This returns a comma separated list of all of the scripts currently running in the system.
None.
Return value: script list
Type: string
Description: This returns all of the currently running script names, separated by commas.
This function will suspend operation of the script and allow the HomeSeer application to run. This is useful if you are waiting for a voice command or some other action that HomeSeer needs to recognize. If this function is not called, a script will time out in 30 seconds and prompt the user to either wait longer or kill the script. If this function is called within the 30 seconds, the script will not time out.
None.
None.
Dim V As Double
Do
V = hs.DeviceValueEx(1234)
If V = 41.66 Then Exit Do
hs.WaitEvents()
hs.WaitSecs(2)
Loop
hs.WriteLog("My Device", "The device has reached the proper value.")
End Sub
This function waits a number of seconds. This will also allow other operations to take place in HomeSeer by giving up the CPU. It will also keep a script from timing out. The function will not return until the number of seconds have elapsed.
Parameter: seconds
Type: integer
Description: This is the number of seconds to wait.
None.
Dim V As Double
Do
hs.WaitEvents()
hs.WaitSecs(2)
Loop
End Sub
In This Section | |
Modifying Voice Recognition Commands Getting Last Voice Command Information Controlling Speaker Clients | |
In This Section | |
AddVoiceCommand ClearAllVoiceCommands | |
This function will add the specified voice command to a new private command list. HomeSeer voice commands are disabled and the computer will only listen for the commands given using this function. When the script is exited, the computer will go back to listening for regular HomeSeer voice commands.
If the script is triggered by a voice command from HomeSeer Phone, make sure you add a system call to clear all voice commands. This will tell HomeSeer Phone to restore the main menu voice commands. The statement is:
system.ClearAllVoiceCommands
Parameter: cmd
Type: string
Description: This is the voice command to add.
Parameter: host (optional)
Type: string
Description: Leaving this a null string will apply the command to the first instance HomeSeer finds, otherwise use the hostname of the computer for this command. If more than one instance of the Speaker application is running on "host" then you may need to specify the instance as well in the format host:instance.
Return value: voice command
Type: string
Description: This is the specified voice command.
The following script will read your E-mail messages.
Dim Count As Integer
Count = hs.MailMsgCount
hs.Speak("You have " & Convert.ToString(Count) & " messages.", False, "")
' If no messages, exit.
If Count < 1 Then Exit Sub
hs.Speak("Would you like me to read your messages to you?", True, "")
' Clear out the last voice command recognized.
hs.LastVoiceCommand = ""
' Create our own private recognition list.
hs.AddVoiceCommand("Yes")
hs.AddVoiceCommand("Sure")
hs.AddVoiceCommand("Please")
hs.AddVoiceCommand("No")
Dim Resp As String = ""
Dim GotResponse As Boolean = False
Dim Start As Date = Now
Do
Resp = hs.LastVoiceCommand
If Not String.IsNullOrEmpty(Resp.Trim) Then
GotResponse = True
Exit Do
End If
hs.WaitEvents()
Loop Until Now.Subtract(Start).TotalSeconds > 15
If Not GotResponse Then
hs.ClearAllVoiceCommands()
hs.Speak("Goodbye.", False, "")
Exit Sub
End If
If Resp.Trim.ToLower = "no" Then
hs.Speak("OK, perhaps later.", False, "")
Exit Sub
End If
For i As Integer = 0 To Count - 1
hs.Speak("Message " & Convert.ToString(i), True, "")
hs.Speak("Left on " & hs.MailDate(i), True, "")
hs.Speak("The message is from,, " & hs.MailFrom(i), True, "")
hs.Speak(" and the subject of the message is " & hs.MailSubject(i), True, "")
hs.Speak(",, would you like me to read you the message?", True, "")
Resp = ""
GotResponse = False
Start = Now
Do
GotResponse = True
Exit Do
End If
hs.WaitEvents()
Exit Sub
End If
Select Case Resp.Trim.ToLower
Case "yes", "sure", "please"
hs.Speak(hs.MailText(i), True, "")
hs.WaitEvents()
End Select
hs.WaitSecs(2)
Next
hs.Speak("That was your last message. Goodbye.", False, "")
End Sub
This function clears all voice commands that were added with AddVoiceCommand.
Parameter: Host (optional)
Type: String
None.
In This Section | |
GetLastVRCollection GetLastVRInfo LastCommandSelected LastVoiceCommand LastVoiceCommandHost LastVoiceCommandInstance LastVoiceCommandPhone LastVoiceCommandRaw | |
This function gets the last voice command recognized by all speaker clients and HomeSeer Phone lines. The return is a simple array of clsLastVR objects.
None.
Return value: LastVR
Type: Array of clsLastVR
Description: This returns the last voice command that HomeSeer recognized on all connected speaker clients and HomeSeer phone lines in an array of clsLastVR objects. Note - if a given speaker client is connected but has not been used for VR since HomeSeer was started, it will not be a part of the returned array.
clsLastVR
GetLastVRInfo
LastCommandSelected
LastVoiceCommand
LastVoiceCommandRaw
clsLastVR is an object class used with GetLastVRInfo and GetLastVRCollection and returns information about the last recognized voice command given to HomeSeer.
Here are the properties of the class:
Property | Type | Description |
Raw | String | This is the raw voice command as it was heard and recognized by the VR engine. |
Parsed | String | This is the parsed voice command. For HomeSeer generated voice commands, this string will contain special indicators for the matched device or event - it will not match the spoken text. |
Host | String | This is the host name of the speaker client the recognized phrase was spoken to, or 'Phone' if it was spoken via HomeSeer Phone's local or remote interaction. |
Instance | String | This is the instance name of the speaker client the recognized phrase was spoken to, or the phone line number if it was spoken via HomeSeer Phone's local or remote interaction. |
VRTime | Date | This is the date/time the phrase was recognized. |
ID | Integer | This is the voice recognition context ID number that was matched for the recognized phrase. |
GetLastVRInfo
GetLastVRCollection
LastCommandSelected
LastVoiceCommand
LastVoiceCommandRaw
This function gets the last voice command recognized by a given speaker client/instance. The return is a clsLastVR object matching the speaker client host name and instance provided.
Parameter: host
Type: string
Description: This is the host name for the speaker client to retrieve the last recognized VR information from.
Parameter: instance
Type: string
Description: This is the instance name for the speaker client to retrieve the last recognized VR information from. Note - if a given speaker client is connected but has not been used for VR since HomeSeer was started, it will not be returned with this command.
Type: clsLastVR
Description: This returns the last voice command that HomeSeer recognized on the given host:instance in a clsLastVR object, or 'nothing' if no matching host:instance was found.
clsLastVR
GetLastVRCollection
LastCommandSelected
LastVoiceCommand
LastVoiceCommandRaw
clsLastVR is an object class used with GetLastVRInfoand GetLastVRCollectionand returns information about the last recognized voice command givento HomeSeer.
GetLastVRInfo
GetLastVRCollection
LastCommandSelected
LastVoiceCommand
LastVoiceCommandRaw
This function gets the event name of the last voice command. This works the same as the LastVoiceCommand function except it will return the actual name of the voice command. This is useful if you wanted to do some other action to the event, like delete it or disable it and you need that actual event name. This is a read-only property.
None.
Return value: event name
Type: string
Description: This returns the name of the event that was triggered by the last voice command.
clsLastVR
GetLastVRInfo
GetLastVRCollection
LastVoiceCommand
LastVoiceCommandRaw
This function gets the last voice command recognized by a speaker client. This is a read-only property. This value is the parsed (processed) voice recognition string, which means that some parts of the command may be replaced by values or codes that HomeSeer uses to interpret what was spoken. See LastVoiceCommandRaw to get the unparsed (raw) phrase.
None.
Type: string
Description: This returns the last voice command that HomeSeer recognized. This is useful for obtaining the actual voice command when the given voice command contains many optional words.
If a voice command was set to:
tv channel (0|1|2|3|4|5|6|7|8|9)
and the user spoke "tv channel 4", this function would return the string "tv channel 4"
Create an event name tv channel. Set the voice command to:
Set the actions of the event to run the following script. When you speak a phrase like "tv channel 2", a message box will pop up giving you the actual command the system recognized.
sub main()
dim v
v=hs.LastVoiceCommand
msgbox "I heard "&v
end sub
clsLastVR
GetLastVRInfo
GetLastVRCollection
LastCommandSelected
LastVoiceCommandRaw
This function gets the host name of the speaker client for the last voice command recognized by a speaker client. This is a read-only property. This command will return "Phone" if the last recognized command came from the a HomeSeer Phone line.
None.
Return value: host name
Type: string
Description: This returns the host name where the speaker client is running that the last voice command that HomeSeer recognized originated from. If the phone interface was used, this command returns the text: Phone
clsLastVR
GetLastVRInfo
GetLastVRCollection
LastCommandSelected
LastVoiceCommand
LastVoiceCommandRaw
This function gets the instance name of the speaker client for the last voice command recognized by a speaker client. This is a read-only property. This command will return a phone line number (e.g. "1", "2", etc.) if the last recognized command came from a HomeSeer Phone line.
None.
Return value: instance name
Type: string
Description: This returns the instance name where the speaker client is running that the last voice command that HomeSeer recognized originated from. If the phone interface was used, this command returns the HomeSeer Phone line number as text.
clsLastVR
GetLastVRInfo
GetLastVRCollection
LastCommandSelected
LastVoiceCommand
LastVoiceCommandRaw
This function gets the last voice command recognized by HomeSeer Phone. This is a read-only property. This value is the parsed (processed) voice recognition string, which means that some parts of the command may be replaced by values or codes that HomeSeer uses to interpret what was spoken. See LastVoiceCommandRaw to get the unparsed (raw) phrase. HomeSeer Phone is required to do voice recognition over the telephone.
None.
Type: string
Description: This returns the last voice command that HomeSeer recognized via the telephone. This is useful for obtaining the actual voice command when the given voice command contains many optional words.
sub main()
dim v
v=hs.LastVoiceCommandPhone
hs.WriteLog "LVCP", "I heard " & v & " from the phone."
end sub
clsLastVR
GetLastVRInfo
GetLastVRCollection
LastCommandSelected
LastVoiceCommand
LastVoiceCommandRaw
This function gets the last voice command recognized by a speaker client or HomeSeer phone in raw (unparsed) format. The unparsed format matches the phrase spoken by the user. This is a read-only property.
None.
Type: string
Description: This returns the last voice command that HomeSeer recognized in unparsed form. In unparsed form, the spoken phrase "Turn on the Kitchen Light" will return the same text. In parsed form, the phrase might return something like "Turn on DV:5427"
clsLastVR
GetLastVRInfo
GetLastVRCollection
LastCommandSelected
LastVoiceCommand
In This Section | |
GetListenStatus ListenMode ListenForCommands SetSpeaker StartListen StopListen | |
This function returns the listening status of a specific speaker client (host or host:instance).
Parameter: host
Type: string
Description: Leaving this a null string will return the status for the first instance HomeSeer finds, otherwise use the hostname of the computer you are interested in determining the listening status of. If more than one instance of the Speaker application is running on "host" then you may need to specify the instance as well in the format host:instance.
Return value: listening status
Type: boolean
Description: TRUE indicates that the speaker app instance is listening.
This function indicates the current listening mode.
None.
Return value: mode
Type: integer
Description: This returns the current listen mode which is define as:
1 = Not Listening
2 = Listening for commands
3 = Listening for attention
This function will switch the computer from either listening for event name commands or listening for the attention phrase.
Parameter: action
Type: boolean
Description: Use TRUE to listen for event name commands and FALSE to listen for the attention phrase.
None.
sub main()
' listen only for attention phrase
hs.ListenForCommands FALSE
end sub
This procedure changes the speaker profile on one or more Speaker clients to the profile name provided.
Parameter: speaker_name
Type: string
Description: This is the name of the speaker profile to switch to. The speaker profile name must match one of the available speaker profiles on the computer that the HomeSeer Speaker client is running on.
Type: string
None.
This function starts the voice recognition engine if it is not already started. For scripts that are to be used over the phone, use the System functions.
Type: string
None.
This function stops the voice recognition engine if it is not already stopped. For scripts that are to be used over the phone, use the System functions.
Type: string
None.
In This Section | |
Global Variables Encryption Counters Timers | |
In This Section | |
CreateVar DeleteVar GetVar SaveVar | |
This function creates a new global variable. The variable may be accessed by the functions SaveVar and GetVar. The variable is global in scope and can only be destroyed with the DeleteVar function or exiting the application.
The variable created is an object and can be used to hold any variable type, including references to objects.
Parameter: name
Type: string
Description: This is the name of the variable.
Return value: error code
Type: string
Description: This is an empty string if there's no error. Otherwise, an error string will be returned if the variable already exists.
dim errst
errst = CreateVar("myvar")
if errst <> "" then
msgbox "Error creating variable"
end if
This function deletes a global variable or reference to an object that was created by CreateVar. If the variable does not exist, the function does nothing.
Parameter: name
Type: string
None.
This function finds the variable associated with the name parameter and returns it.
Parameter: name
Type: string
Return value: variable item
Type: variant
Description: This returns the variable saved.
dim myvar
myvar = hs.GetVar("myvar")
' if "myvar" is an object, then get the variable with:
set myvar = hs.GetVar("myvar")
This function saves the variable contained in the obj parameter. The parameter may be any variable type such as a string or integer, or it may be a reference to an object created with CreateObject.
Parameter: name
Type: string
Parameter: obj
Type: object
Description: This is the object to be saved.
Type: string
Description: This returns an empty string if no error occurred and returns an error string if one did occur.
dim errst
dim myvalue
myvalue = 10
errst = hs.SaveVar("myvar",myvalue)
In This Section | |
EncryptString EncryptStringEx DecryptString | |
This function encrypts a string using an encryption password that you specify. Although many unprintable characters can be written to a text file successfully, Windows terminates a text string with a carriage return/line-feed character combination. The bRecurse parameter is provided to cause the function to recursively encrypt the data until it detects no carriage return or line-feed characters in it. The string may then be written to a text file such as when you save it in an INI file using SaveINISetting. Using bRecurse on a large amount of text is NOT recommended as it may recursively encrypt for a long time in an attempt to remove carriage return and line-feed characters, or the function may result in an error due to too many attempts to recursively encrypt. Another solution for writing encrypted data to a text file safely is to convert it to a text representation of HEX data. See the example below.
Parameter: sToEncrypt
Type: string
Description: This is the text that you want encrypted.
Parameter: sPassword
Type: string
Description: This is the user-created text string to encrypt the text with.
Return value: data
Type: string
Description: This returns a string containing an encrypted form of sToEncrypt, encrypted using sPassword. This string is not limited to printable characters only, so care should be taken in the storage of this data in files.
If Parms Is Nothing Then Exit Sub
' Encrypt the combination to my vault full of money. The combination
' that I just entered is stored in the variable sCombEntered.
Dim sCombEntered As String = Convert.ToString(Parms)
Dim sCombination As String = ""
sCombination = hs.EncryptString(sCombEntered, "For Spouse Only Spend Wisely", False)
' I now have my encrypted combination in sCombination. I must remember
' to use HomeSeer's or Microsoft's script encrypters on this script
' since my password string is plainly visible above!
' I want to store the combination in a text file, so let's Base64 encode it.
Dim bteArray() As Byte
bteArray = Encoding.ASCII.GetBytes(sCombination)
Dim sOutput As String = ""
sOutput = Convert.ToBase64String(bteArray, Base64FormattingOptions.None)
' Now I have sOutput as a text representation of bytes, I can write that to an INI
' file and reverse the process of encoding it to Base64 to unencode it.
hs.SaveINISetting("Passwords", "Vault", sOutput, "MyPasswords.ini")
End Sub
Encrypted strings using this function are encrypted using strong (AES/Rijndael) encryption - the data can NOT be recovered if the password(s) are lost. The resulting data may have unprintable characters, so you may not be able to save it using INI functions. Another solution for writing encrypted data to a text file safely is to convert it to a text representation of HEX data. See the example used in EncryptString.
Parameter: Text
Type: String
Parameter: Password
Type: String
Parameter: KeyModifier
Type: String
Description: This parameter may be used to provide further user-specific encryption of the data - it is a modifier used with the password parameter to create the encryption key.
Return value: data
Type: string
Description: This returns a string containing an encrypted form of Text, encrypted using Password (and KeyModifier if provided). This string is not limited to printable characters only, so care should be taken in the storage of this data in files.
This function decrypts a string using a decryption password that you specify.
Parameter: sToDecrypt
Type: String
Description: This is the text that you want decrypted (unencrypted).
Type: String
Parameter: KeyModifier (Optional)
Type: String
Description: This optional parameter is the modifier text to use with the password to create the key - if EncryptStringEx was used to encrypt the string and a key modifier was used, you must specify the same key modifier here.
Return value: Data
Type: String
Description: This returns a string containing a decrypted form of sToDecrypt, decrypted using sPassword. Only the same value of sPassword used to encrypt the string will return the original string in this function.
' Decrypt the combination to my vault full of money.
' First I have to read the encrypted string from a file and unencode it.
' The string was Base64 encoded so that it could be safely written to a text file.
sCombination = hs.GetINISetting("Passwords", "Vault", "NOTHING", "MyPasswords.ini")
If sCombination Is Nothing OrElse String.IsNullOrEmpty(sCombination.Trim) Then
hs.WriteLog("Error", "Encrypted combination was not read from the INI file properly.")
Exit Sub
End If
If sCombination.Trim.ToLower = "nothing" Then
hs.WriteLog("Warning", "The encrypted vault password was not found in our passwords INI file.")
Exit Sub
End If
' Now decode the string back into an array of bytes.
bteArray = Convert.FromBase64String(sCombination)
Dim sCombEntered As String = ""
sCombEntered = Encoding.ASCII.GetString(bteArray)
' Now we have the encrypted combination, so let's decrypt it. (We'll re-use sCombination)
sCombination = hs.DecryptString(sCombEntered, "For Spouse Only Spend Wisely")
' I now have my decrypted combination in sCombination. I must remember
End Sub
Return the value of a counter.
Parameter: CounterName
Type: String
Description: The name of the counter.
Return value: Result
Type: Double
Description: Returns the counter value.
dim value as Double = hs.CounterValue("mycounter")
Resets a counter to 0. If any events are waiting on the change of the counter, they may trigger when this sub is called.
Type: String
Description: The name of the counter to reset.
Return value: Nothing
Description: This is a Sub and does not return a value.
hs.CounterReset("mycounter")
Increments a counter. If any events are waiting on a change to the counter, they may trigger.
Type: String
Description: The name of the counter to increment.
Description: This is a Sub and does not return a value;
hs.CounterIncrement("mycounter")
Decrementsa counter. If any events are waiting on a change to the counter, they may trigger.
Type: String
Description: The name of the counter to decrement.
hs.CounterDecrement("mycounter")
Retrieve the value of a specific named timer.
Parameter: TimerName
Type: String
Description: The name of the timer to retrieve the value from.
Return value: Timer Value
Type: TimeSpan
Description: A TimeSpan object that represents the timer.
dim ts as TimeSpan = hs.TimerValue("mytimer")
Reset a timer to 0.
Type: String
Description: The name of the timer to reset.
hs.TimerReset("mytimer")
In This Section | |
Time Related Calendar Related | |
In This Section | |
LocalTimeZone SolarNoon Sunrise SunriseDt Sunset SunsetDt TimeZoneName | |
This function returns an offset in minutes from UTC (Universal Time Coordinate) for your time zone. The offset is based upon UTC, which is the time standard used since 1972, and not GMT, which was the previous standard.
None.
Return value: Offset
Type: Integer
Description: This returns the current time zone offset from UTC for the time zone set on your HomeSeer computer.
hs.WriteLog "TimeZone","My timezone offset here in Eastern Daylight Time from UTC is " & CStr(hs.LocalTimeZone / 60) & " hours."
Results in this being written to the log:
4/14/2004 3:00:00 PM~!~TimeZone~!~My timezone offset here in Eastern Daylight Time from UTC is 5 hours.
This function returns the time of solar noon. This is a read-only property.
None.
Return value: solar noon time
Type: date
Description: This is a date item representing the time of solar noon, the period at which the sun appears directly overhead a location.
sub main()
dim t
t=hs.SolarNoon
msgbox "Solar Noon is at " & FormatDateTime(t, vbLongTime)
end sub
This function returns the time of sunrise. This is a read-only property.
None.
Return value: sunrise time
Type: string
Description: This is a string representing the time of sunrise. The string returned is formatted according to your system's setting for time display but with seconds removed (e.g., if there are three fields separated by colons, the third one is removed).
sub main()
dim t
t=hs.Sunrise
msgbox "Sunrise is at " & t
end sub
None.
Type: date
Description: This is a date type representing the time of sunrise.
sub main()
dim t
t=hs.SunriseDt
msgbox "Sunrise is at " & FormatDateTime(t, vbLongTime)
end sub
This function returns the time of sunset. This is a read-only property.
None.
Return value: sunset time
Type: string
Description: This is a string representing the time of sunset. The string returned is formatted according to your system's setting for time display but with seconds removed (e.g., if there are three fields separated by colons, the third one is removed).
sub main()
dim t
t=hs.Sunset
msgbox "Sunset is at " & t
end sub
None.
Type: date
Description: This is a date type representing the time of sunset.
sub main()
dim t
t=hs.SunsetDt
msgbox "Sunset is at " & FormatDateTime(t, vbLongTime)
end sub
This function returns the name of the PC's time zone setting. This is a read-only property.
None.
Return value: time zone
Type: string
Description: This is the name of the time zone as read from the operating system.
sub main()
dim t
t=hs.TimeZoneName
msgbox "The TimeZone is " & t
end sub
This function returns whether daylight savings is currently active. This is a read-only property.
None.
Return value: Currently in daylight savings
Type: Boolean
Description: The return value (TRUE or FALSE) indicates whether the current date falls under daylight savings time as reported by the operating system. Daylight savings is not used in all locations.
sub main()
if hs.DayLightSavings then
hs.WriteLog "We are currently in daylight savings!"
end if
end sub
This function returns the number of days in the month of a date value supplied to it.
Parameter: Date
Type: Date
Description: This is a date object for which you wish to know how many days are in that month. The day of the month in the date object is ignored.
Return value: number of days
Type: Integer
Dim dte As Date = DateTime.Parse("April 1, 2006")
hs.WriteLog("Info","There are " & hs.DaysInMonth(dte).ToString & " days in the month of April, 2006")
DaysLeftInMonth
DaysLeftInYear
WeekNumber
WeeksLeftInYear
This function returns a value indicating how many days are left in the current month.
None.
Return value: Number of days
Type: Integer
Description: The number of days remaining in the current month.
hs.WriteLog("Info","There are " & hs.DaysLeftInMonth.ToString & " days left in the month.")
DaysInMonth
DaysLeftInYear
WeekNumber
WeeksLeftInYear
This function returns a value indicating how many days are left in the current year.
None.
Type: Integer
Description: The number of days remaining in the current year.
hs.WriteLog("Info","There are " & hs.DaysLeftInYear.ToString & " days left in the year.")
DaysInMonth
DaysLeftInMonth
WeekNumber
WeeksLeftInYear
This function returns a value indicating whether the provided day of the month is even or odd.
Parameter: date
Type: date
Description: This is the date that you wish to check for being even or odd for the month.
Return value: CD_DAY_EvenOdd
Type: Enum (Integer) 0 = Even, 1 = Odd
Description: The return is a .NET Enum equivalent to an integer value.
The return value converted to string with the .ToString method will return the word Even or Odd,
but when converted to an integer value and then to a string it will display 0 or 1.
hs.WriteLog("Info","April 1 of 2006 is an " & hs.EvenOddMonth(dte).ToString & " day of the month.")
This function returns a value indicating whether the provided day of the year is even or odd.
(The day of the month may be odd, but it may still be an even number for the year.)
Parameter: date
Type: date
Description: This is the date that you wish to check for being even or odd for the year.
hs.WriteLog("Info","April 1 of 2006 is an " & hs.EvenOddDay(dte).ToString & " day.")
This function returns a date representing the last weekday of the month from the date provided.
Parameter: date
Type: date
Description: This is a date in the month for which you wish to know the date of the last weekday of that month.
Return value: last weekday date
Type: date
Description: The date of the last weekday of the month.
hs.WriteLog("Info","The last weekday of April 2006 is " & hs.GetLastWeekday(dte).ToShortDateString)
IsWeekday
IsWeekend
Weekdays
WeekendDays
This function returns a date object representing the requested special date. e.g. The Third Thursday of November.
Parameter: DOW
Type: DayOfWeek (Enum - Integer)
Description: This is the day of the week value you are looking for. The values for the Enum are as follows:
SUNDAY = 0
MONDAY = 1
TUESDAY = 2
WEDNESDAY = 3
THURSDAY = 4
FRIDAY = 5
SATURDAY = 6
WEEKDAY = 7
WEEKEND_DAY = 8
Parameter: Instance
Type: CD_DAY_IS_Type (Enum - Integer)
Description: This is the instance day that you wish to retrieve, using these values:
FIRST = 1
SECOND = 2
THIRD = 3
FOURTH = 4
LAST = 5
Parameter: For Month
Type: date
Description: This date object references the month you are requesting the special date for - the day component of the month is not used. For example, to get the third Thursday in November of 2006, provide a date object set to any day/time in the month of November, 2006.
Optional Parameter: GetNext
Type: Boolean (Default value if not provided = False)
Description: If the requested special date has already passed and GetNext is True, then the next instance of the requested special day will be returned. (See the example below)
Return value: date requested
Type: date
Description: This is a date object with the month, day, year components for the special day requested.
Sub Main(parm as object)
Dim DOW as Integer = 3 ' Wednesday
Dim Inst as Integer = 3 ' Third instance (e.g. Third Wednesday of the month)
Dim ForMonth As Date = DateTime.Parse("February 3, 2006")
Dim dteReturn As Date
dteReturn = hs.GetSpecialDay(DOW, Inst, ForMonth, False)
hs.WriteLog("Test","With GetNext False, Result is " & dteReturn.ToShortDateString)
dteReturn = hs.GetSpecialDay(DOW, Inst, ForMonth, True)
hs.WriteLog("Test","With GetNext True, Result is " & dteReturn.ToShortDateString)
End Sub
The example above returns:
~!~Test~!~With GetNext False, Result is 2/15/2006
~!~Test~!~With GetNext True, Result is 3/15/2006
This function returns a Boolean (True/False) indicating if a date provided is the special day indicated.
Parameter: In Date
Type: date
Description: This date object references the date you wish to check.
Parameter: DOW
SUNDAY = 0
MONDAY = 1
TUESDAY = 2
WEDNESDAY = 3
THURSDAY = 4
FRIDAY = 5
SATURDAY = 6
WEEKDAY = 7
WEEKEND_DAY = 8
Parameter: Instance
Description: This is the instance day that you wish to compare, using these values:
FIRST = 1
SECOND = 2
THIRD = 3
FOURTH = 4
LAST = 5
Type: date
Return value: Is Special
Type: Boolean (True/False)
Description: If In Date matches the special day information indicated with the other three parameters, then Is Special will be True, otherwise False.
Dim InDate As Date = DateTime.Parse("February 15, 2006")
Dim bReturn As Boolean
bReturn = hs.IsSpecialDay(InDate, DOW, Inst, ForMonth)
If bReturn = True Then
hs.WriteLog("Test","February 15 is the third Wednesday of February, 2006")
Else
End If
End Sub
This function returns a Boolean (True/False) value indicating whether the date provided is a weekday or not.
Parameter: date
Type: date
Description: This is the date that you wish to check.
Return value: Weekday
Type: Boolean
Description: If the date provided falls upon a weekday (Monday through Friday), then this return will be True, otherwise False.
GetLastWeekday
IsWeekend
Weekdays
WeekendDays
This function returns a Boolean (True/False) value indicating whether the date provided is a weekend day or not.
Parameter: date
Type: date
Return value: Weekend
Type: Boolean
Description: If the date provided falls upon a weekend day (Saturday or Sunday), then this return will be True, otherwise False.
GetLastWeekday
IsWeekday
Weekdays
WeekendDays
This subroutine accepts an input date, and returns into the variables you provide, the values of various moon phase data points including the dates of the new and full moon, the current cycle value, and the moon phase description.
Parameter: dateStart
Type: Date
Description: This is the date for which you wish to retrieve moon phase information.
Parameter: NewMoon
Type: Date
Description: After the sub-routine completes, this variable will contain the date of the new moon relative to the provided starting date.
Parameter: FullMoon
Type: Date
Description: After the sub-routine completes, this variable will contain the date of the full moon relative to the provided starting date.
Parameter: Cycle
Type: Integer
Description: After the sub-routine completes, this variable will contain the value of the moon cycle on the date provided by the starting date.
Parameter: Description
Type: String
Description: This is the name of the current moon cycle.
None
Dim dtStart as Date = Now
Dim NMoon as Date
Dim FMoon as Date
Dim CurCycle as Integer
Dim sDesc as String = ""
hs.Moon(dtStart, NMoon, FMoon, CurCycle, sDesc)
hs.WriteLog("Moon","New on " & NMoon.ToShortDateString & ", Full on " & FMoon.ToShortDateString & _
", Cycle is " & CurCycle.ToString & " = " & sDesc)
End Sub
The above example returns:
Moon - New on 8/24/2006, Full on 9/7/2006, Cycle is 24 = Waning Crescent
This function returns the number of weekdays between two dates, inclusive of the end date.
Parameter: Date Start
Type: date
Description: This is the starting date.
Parameter: Date End
Type: date
Description: This is the ending date.
Return value: Weekdays
Type: integer
Description: This is the number of weekdays between the two dates including the ending date if it is a weekday.
Dim dtStart as Date = DateTime.Parse("8/1/2006")
Dim dtEnd as Date = DateTime.Parse("8/10/2006")
Dim iResult as Integer
iResult = hs.Weekdays(dtStart, dtEnd)
hs.WriteLog("Weekdays","There are " & iResult.ToString & " weekdays between the dates.")
End Sub
The above example returns this result:
Weekdays - There are 7 weekdays between the dates.
GetLastWeekday
IsWeekday
IsWeekend
WeekendDays
This function returns the number of weekend days between two dates, inclusive of the end date.
Type: date
Parameter: Date End
Type: date
Type: integer
Description: This is the number of weekend days between the two dates including the ending date if it is a Saturday or Sunday.
Dim dtEnd as Date = DateTime.Parse("8/13/2006")
iResult = hs.WeekEndDays(dtStart, dtEnd)
hs.WriteLog("WeekEndDays","There are " & iResult.ToString & " weekend days between the dates.")
End Sub
WeekEndDays - There are 4 weekend days between the dates.
GetLastWeekday
IsWeekday
IsWeekend
Weekdays
This function returns the week number of the year for the given date, and assumes the first full week starting on Sunday of the year as Week 1. For other options on the first week of the year, use WeekNumberEx.
Parameter: In Date
Type: date
Description: This is the date for which you wish to know the week number.
Return value: WeekNumber
Type: short integer
Description: This is the week number of the year for the given date.
DaysInMonth
DaysLeftInMonth
DaysLeftInYear
WeeksLeftInYear
WeeksLeftInYearEx
WeekNumberEx
This function returns the week number of the year for the given date, just like WeekNumber, except that you can specify the conditions for determining the first week of the year.
Parameter: In Date
Type: date
Parameter: Week Mode
Type: Integer
Description: This specifies how the first week of the year is determined, according to the following table:
Week Mode Value | Result |
1 | The first week of the year starts with the first calendar day of the year, regardless of the day of the week it falls upon. |
4 | The first week of the year is determined by the first week with at least four days in the new year. |
(Anything Else) | The first week of the year is determined by the first full week starting on Sunday in the new year. |
Type: Integer
Description: This is the week number of the year for the given date and Week Mode.
DaysInMonth
DaysLeftInMonth
DaysLeftInYear
WeeksLeftInYear
WeeksLeftInYearEx
WeekNumber
This function returns the number of weeks left in the current year based upon the first week of the year being the first full week starting on a Sunday. For other starting week options, see WeeksLeftInYearEx.
None.
Return value: Weeks Left
Type: Integer
Description: This number represents the number of weeks remaining in the current year based upon the first week being the first full week starting on Sunday of the year.
DaysInMonth
DaysLeftInMonth
DaysLeftInYear
WeekNumber
WeekNumberEx
WeeksLeftInYearEx
This function returns the number of weeks left in the current year, based upon the starting week mode provided as a parameter.
Type: integer (Optional)
Type: short
Description: This number represents the number of weeks remaining in the current year as determined by the week mode parameter.
DaysInMonth
DaysLeftInMonth
DaysLeftInYear
WeekNumber
WeekNumberEx
WeeksLeftInYear
In This Section | |
GetInstanceList IsSpeakerBusy SpeakToFile Speaker Client Global Audio Media Only Procedures Text-to-Speech Only Procedures | |
This function retrieves a comma separated list of host:instance names for Speaker client instances currently connected to HomeSeer.
None.
Return value: instance list
Type: string
Description: The returned instance list is a comma separated list of host:instance pairs as in this example:
Bandit:Default,Johnny:Default,Race:Music,Race:Default
This function can let you know if a specific speaker client (host or host:instance) is currently busy speaking or playing WAV audio.
Parameter: Host (Optional)
Type: String
Description: Leaving this a null string will return the busy status for the first instance HomeSeer finds, otherwise use the hostname of the computer you are interested in determining the busy status of. If more than one instance of the Speaker application is running on "host" then you may need to specify the instance as well in the format host:instance.
Return value: busy status
Type: boolean
Description: TRUE indicates that the speaker application instance is busy.
This function speaks some text and saves the result in a WAV file.
Parameter: Text
Type: String
Description: This is the string you want to speak.
Parameter: Voice
Type: String
Description: This is the name of the voice you want to use for speaking. This string must match the voice name exactly. Voice names can be found in the Speaker Client. If the name is omitted, the default voice as specified in the computer's speech control panel is used.
Parameter: Filename
Type: String
Description: This is the full path to the file where the voice output will be saved.
None.
sub main()
hs.SpeakToFile "Hello from a file!", "ATT DTNV 1.3 Crystal","c:\voice.wav"
end sub
In This Section | |
SetVolume GetVolume GetMuteStatus GetPauseStatus MuteAudio PauseAudio UnMuteAudio UnPauseAudio | |
This function sets the master volume of the system sound device that the speaker client(s) are using. This can be used to set the volume of the text-to-speech output. The volume level must be in a range between 0 and 100, where 100 is the maximum volume.
To change the volume for the MEDIA functions, use MediaVolume.
Parameter: Level
Type: Integer
Description: This is the volume level, from 0 to 100.
Type: String
None.
sub main()
hs.SetVolume 90
hs.speak "I am speaking louder",TRUE
hs.SetVoume 20, "Kitchen"
hs.speak "I am speaking softer on the Kitchen computer than on the others.",TRUE
end sub
This function returns the volume level of an instance of the Speaker client program running on a computer.
Type: String
Description: Leaving this a null string will return the volume level for the first instance HomeSeer finds, otherwise use the hostname of the computer you are interested in determining the volume level of. If more than one instance of the Speaker application is running on "host" then you may need to specify the instance as well in the format host:instance.
Return value: Volume level
Type: Integer
Description: The volume level is returned using a 0-100 scale, 100 being full volume.
This function returns the mute status of a specific speaker client (host or host:instance).
Type: String
Return value: Mute Status
Type: Boolean
Description: TRUE indicates that the speaker app instance is muted.
This function returns the "pause" status of a specific speaker client (host or host:instance).
Type: String
Description: Leaving this a null string will return the status for the first instance HomeSeer finds, otherwise use the hostname of the computer you are interested in determining the pause status of. If more than one instance of the Speaker application is running on "host" then you may need to specify the instance as well in the format host:instance.
Return value: Pause Status
Type: Integer
Description: Bit encoded value indicating the status as follows:
Bit Values | Status |
Bit 1 = 0 | No Wavefile Instance |
Bit 1 = 1 | Wavefile Present |
Bit 2 = 0 | Wavefile Paused |
Bit 2 = 1 | Wavefile Playing |
Bit 3 = 0 | TTS Present |
Bit 3 = 1 | No TTS Present |
Bit 4 = 0 | TTS is currently speaking |
Bit 4 = 1 | TTS is not speaking |
This function mutes all speech and audio of a specific speaker client (host or host:instance).
Type: String
Description: Leaving this a null string will mute the first instance HomeSeer finds, otherwise use the hostname of the computer you are interested in muting. If more than one instance of the Speaker application is running on "host" then you may need to specify the instance as well in the format host:instance.
None.
This function pauses the audio currently playing at a specific speaker client (host or host:instance).
Type: String
Description: Leaving this a null string will pause the audio for the first instance HomeSeer finds, otherwise use the hostname of the computer you are interested in pausing audio on. If more than one instance of the Speaker application is running on "host" then you may need to specify the instance as well in the format host:instance.
None.
This function resumes all speech and audio of a specific speaker client (host or host:instance).
Type: String
None.
This function resumes the audio currently playing at a specific speaker client (host or host:instance).
Type: String
None.
In This Section | |
MediaFilename MediaPlay MediaPause MediaMute MediaIsPlaying MediaStop MediaUnPause MediaVolume | |
This is a read/write property. This function sets the file name that is to played using the speaker client. Call MEDIAPlay to actually start playing the selection.
This property may be read to get the selection currently playing.
Parameter: filename
Type: string
Description: This sets the file name of the media selection to play. The file name may be any valid file supported by the Windows® Media Player.
Type: string
None.
This function starts playing the selection as specified with the hs.MEDIAFilename property.
Parameter: filename (optional)
Type: string
Description: This is the path and filename of the file to be played. If it is omitted here, it must have been previously set using the MEDIAFilename property.
Type: string
None.
This function instructs the Windows® Media Player to pause the currently playing selection. The selection may be resumed by calling the hs.MediaPlay function.
Type: string
None.
This function mutes the media selection that's currently playing. The selection continues to play, but sound is not heard.
Parameter: mute
Type: boolean
Description: Use TRUE to mute the selection and FALSE to unmute it.
Type: string
None.
sub main()
' mute the Windows Media Player
hs.MediaMute TRUE
end sub
This function checks if the media player is currently playing a selection.
Type: string
Type: boolean
Description: This returns TRUE if a media selection is currently playing and the sound card is most likely busy, and returns FALSE if a media selection is not playing and the sound is most likely free.
This function instructs the Windows® Media Player to stop playing the current selection.
Type: string
None.
This function instructs the Windows® Media Player to resume the currently playing selection.
Type: string
None.
This is a read/write property. It sets and gets the current volume level of the playing media selection.
Parameter: Level
Type: Integer (property)
Description: This sets the volume level. 100=full volume and 0 is the lowest volume.
Type: String
None.
sub main()
' get the current volume level
dim level
level = hs.MediaVolume
' set the volume to full
hs.MediaVolume = 100
end sub
In This Section | |
Speak SpeakEx SpeakProxy GetVoiceName MuteSpeech SetSpeakingSpeed SetVoice StopSpeaking PlayWavFile PlayWavFileVol | |
This function speaks some text.
Parameter: Text
Type: String
Description: This is the string you want to speak. It may also be the complete path to a WAV file to be played.
Parameter: Wait (Optional)
Type: Boolean
Description: If set to TRUE, the function will not return until the system finishes speaking. This is useful if you are switching between speaking and listening. You cannot listen and speak at the same time on some systems. If this parameter is missing, the system will not wait.
Type: String
None.
Sub Main()
' speak and wait
hs.speak "hello there", True
hs.speak "Hello people in the kitchen.", True, "Kitchen:*"
End Sub
"Using Replacement Variables" in the HomeSeer help file.
This function speaks some text and sends the output to the indicated output device. This function can be used to speak out other sound devices other than the normal sound card. For systems with multiple sound cards, this function can be used to select the specific card.
Parameter: device
Type: integer
Description: This is the device number of the output device. Device 0 is usually the computer speakers and the default sound card.
Parameter: text
Type: string
Description: This is the text you want to speak.
Parameter: wait
Type: boolean
Type: String
None.
This function speaks some text after being handled by a speaker proxy program or plug-in. This command passes along speak commands received from HomeSeer as a registered speaker proxy handler, and this is where the values for the parameters are provided. Therefore, this command is generally NOT used by a script and is primarily for plug-ins and applications.
Parameter: Device
Type: Integer
Description: This is the sound device ID number for the TTS to be spoken at.
Parameter: Text
Type: String
Parameter: Wait
Type: Boolean
Type: String
None.
This function returns the voice name of a specific speaker client (host or host:instance).
Type: String
Description: Leaving this a null string will return the voice name for the first instance HomeSeer finds, otherwise use the hostname of the computer you are interested in determining the voice name being used. If more than one instance of the Speaker application is running on "host" then you may need to specify the instance as well in the format host:instance.
Return value: voice name
Type: string
This function temporarily mutes the speech output. By setting this property to FALSE, all speech output is silenced until this property is set back to TRUE. This mutes ALL speech, including speech generated from scripts.
Parameter: Mode
Type: Boolean
Description: Use TRUE to have speech output silenced and FALSE to have it enabled.
None.
' stop all speech output
sub main()
hs.MuteSpeech = TRUE
end sub
' enable all speech output
sub main()
hs.MuteSpeech = FALSE
end sub
This function sets the rate of HomeSeer's speech.
Parameter: Speed
Type: Integer
Description: This is the speed parameter to be set. The range is -10 to 10. A value of zero is the normal rate of speaking.
Type: String
Description: Leaving this a null string will set the speaking speed for the first instance HomeSeer finds, otherwise use the hostname of the computer you are interested in setting the speaking speed on. If more than one instance of the Speaker application is running on "host" then you may need to specify the instance as well in the format host:instance.
Return value: previous speed or 99
Type: integer
Description: This returns the previous speed setting or returns 99 if the input parameter was invalid. This is useful for returning the speaking speed to its previous value after making an adjustment.
This command changes the voice of a speaker client instance to the voice name provided.
Parameter: VoiceName
Type: String
Description: This is the voice name string of the voice you wish to change the speaker client to use - it is not case sensitive but must match one of the voice names in your system. (See the Speaker Client for a list of voice names.)
Type: String
Description: Leaving this a null string will change the voice for the first instance HomeSeer finds, otherwise use the hostname of the computer you are interested in changing the voice of. If more than one instance of the Speaker application is running on "host" then you may need to specify the instance as well in the format host:instance.
Return value: return status
Type: integer (.NET Short)
Description: Zero (0) means the voice was not found, One (1) indicates success.
This function causes any speaking to stop immediately.
Type: String
None.
hs.StopSpeaking
This function plays a specific WAV file out the default audio device. For more control over playing WAV files, see PlayWavFileEx.
Parameter: FileName
Type: String
Description: This is the complete path to the WAV file to play.
Type: String
Type: Boolean
Description: Setting this to True will cause the command to wait until the WAV file is done playing before continuing. By default, it will not wait.
None.
This function plays a WAV file and allows playing the WAV file in the background and setting the volume level.
Parameter: Filename
Type: String
Parameter: volume (left)
Type: Integer
Description: This is the volume level to use when playing. The range is 0 to 100. Set the value to -1 if you want to use the currently set volume level. In previous versions of HomeSeer this was the LEFT volume level only - note that this is now the one and only volume level.
Parameter: volume (right)
Type: Integer
Description: This parameter is obsolete and remains for backward compatibility with previous versions of HomeSeer.
Type: String
Parameter: Wait
Type: Boolean
Description: Use TRUE to not return until the WAV file has finished playing and FALSE to play the WAV file in the background. The function returns immediately.
None.
