Use these settings to configure your security cameras for use with HS4 and MyHS. To access these settings, click Setup, then Cameras.
Camera Recording
Auto Detected Cameras
Manually Added Cameras
Use the settings in this section to add cameras that are not auto-detected by HS4. You will likely need to check the manual or manufacturer's website to obtain this information. Online camera databases are sometimes helpful too: https://www.ispyconnect.com/sources.aspx
Save Your Work!
Be sure to click the SAVE button at the bottom of the page after you're finished editing.
