Our Zigbee plugin requires the use of a Nortek HUSBZB-1 Z-Wave & Zigbee combo interface. However, the drivers for this product are not automatically installed by Windows. Follow the steps below to install the drivers onto your HS4-powered Windows 7, 8 or 10 system. Note: Early HomeTroller S6 hubs were equipped with Windows 7. Be sure to check your OS before driver installation.
Driver Installation Video: https://www.youtube.com/embed/wJ5--gXZtD4
Windows 10
- Download the Silicon Labs CP210x driver for Window 10.
- Extract the zip file to a folder on your desktop.
- Open Windows Device Manager, you can press the Windows key and type Device Manager to locate it.
- Expand the Other Devices section, then locate the HubZ Zigbee Com Port. Make a note of which COM port this device is using as we will need it later.
- Right click on the device, then select Update Driver.
- Click Browse my computer for driver software, then Let me pick from a list of available drivers on my computer.
- Leave Show All Devices checked, then click Next and Have Disk.
- Click Browse... Navigate to the folder you extracted the files to in step 2.
- Select the file silabser.inf, click Open, then click OK.
- Click Silicon Labs CP210x USB to UART Bridge and then Next.
- If you get a warning that Windows cannot confirm the device ID, click Yes to continue.
Your Zigbee interface should now appear in the Ports (COM & LPT) section of the Device Manager with a different name. You are all set to setup the Zigbee plugin now!
Windows 7 or 8
- Download the Silicon Labs CP210x driver for Windows 7 or 8.
- Navigate to the folder you created and run CP210xVCPInstaller_x86.exe if you have 32 bit Windows or CP210xVCPInstaller_x64.exe for 64 bit Windows. Follow the instructions in the installer until it is complete.
- Scroll through the computer hardware list and select Ports (COM & LPT), then Next.
- Find Silicon Labs in the manufacturer list, select it and then Silicon Labs CP210x USB to UART Bridge in the model lest. Then click Next.
- You will receive an "Update Driver Warning", click Yes.
Plugin Setup
See here for the next step in Zigbee Plugin and Device Setup
