1. Mouse over the TOOLS tab at the top of the page, then click Setup.
  2. Click the Check for Update button to make sure that you are about to install the latest stable release.
  3. If an update is available, click the Install Version 3.0.x.x button. Once you do, the system will inform you that it is about to restart, and you will be brought to a page with a countdown timer. You will be automatically redirected to your HS3 system when this is complete.
Note that you will see an option to update to a beta release of HS3. These are releases which are currently being tested, and are not guaranteed to be entirely stable. Unless there is a specific fix or feature you are looking for, we recommend ignoring beta updates.
