After creating a backup, you may need to restore it if you are installing HS4 on a new system or if something happens to your installation.
NOTE: If you have the Z-Wave GUI plugin installed, you will first need to navigate to Plugins > Z-Wave GUI > Settings. From here, click the Show Legacy Z-Wave Menu toggle, then Save. You can now complete the instructions below as outlined.
Step 1: Restoring your HS4 Configuration
Step 2: Restoring Z-Wave
If you are using the same Z-Wave interface as when your backup was created, try controlling devices from the Devices page as they may already be set up and running.
