Information on updating an existing Z-Wave plugin.
If you have an update available on your Installed plugins page, simply click the update button! If Z-Wave 3.0.2.0 or lower installed and do not see an update available. This guide will show you how to update your current install on HS4 and HS3.
Procedure
When updating your Z-Wave plugin, your existing plugin install will be overwritten but your Z-Wave DATA will not be affected. See the notes below for additional information.
HS4 Update
  1. Go to Plugins→Add
  2. Click the Sync Packages icon in the top right
  3. Locate the Legacy section in the Add Plugins page.
  4. Locate Z-Wave Core at the bottom. Alternatively, you can search for "z-wave" or find Z-Wave Core in the list.
  5. Click on the plugin card and select Install.
  6. Once the Install is finished you will get a confirmation and be brought to the Installed section of Plugins.
  7. You may need to restart the plugin by toggling it off and back on.
HS3 Update
  1. Go to Plug-ins→Manage
  2. Click Update Listings
  3. Check the update box for your Z-Wave plugin
  4. Click Download and Install
  5. Once finish, you may need to restart your plugin by toggling the Enable off and back on.
Notes
If you are seeing INFO: Start Pending as your plugin status. You need to disable and reenable the plugin. If you are still seeing this error after a system restart, reinstall the plugin via the above instructions.
If you still have an entry for HomeSeer Z-Wave alongside your new Z-Wave entry on the Installed plugins page, you can disable and remove the older version. Make sure to keep version 3.0.7.0 or later.
