Add a Dashboard
This article will show you how to add a dashboard to HomeSeer Mobile.
On Android:
While in the Dashboard section of the app, tap the three-dot menu in the top right corner of the screen. You will see a menu appear, and the first option will be New Dashboard. You will then be prompted to submit a name for the new dashboard. Once you click Submit, you will be brought to the new dashboard.
On iOS:
While in the Dashboard section of the app, tap the three-dot menu in the top right corner of the screen. You will see a menu appear, and the second option will be New Dashboard. You will then be prompted to name your new dashboard and save it.
