Change Systems
This article will show you how to change from one system to another on HomeSeer Mobile.
Android
Go to the System Menu by swiping from the left edge of the screen or clicking the hamburger menu button as seen below.
https://s3.amazonaws.com/helpscout.net/docs/assets/576175c3903360713dcecf19/images/5b3fd0590428630abc0bcc0b/file-IbHQrdKdYz.jpg
Next, select Change System
https://s3.amazonaws.com/helpscout.net/docs/assets/576175c3903360713dcecf19/images/5b3fd0e22c7d3a099f2e4562/file-AtZx859A5O.jpg
iOS
Tap on System in the upper left corner of the screen and the System Menu will appear.
Tap Change System, and a list of your systems will appear, from which you can select the system you would like to connect to.
You will then be brought to the first dashboard you have for that system.
Note: This feature is only available to MyHS Premium subscribers. More information is available here.
