Configuring Device Settings on HSM200 (HS3)
The HSM200 has some Device Settings that can be configured.
  1. Open the VIEW drop menu and select Device Management (or click HOME) and click on the Root device for your HSM200.
  2. Click on the Z-Wave tab at the top to go to the Z-Wave Device control page.
  3. On this page you have the options to Rescan, Remove Bad Node, Replace Node, Test Connectivity, Optimize, Full Optimize, and Audit This Node. Expand the Settings section below these buttons.
  4. In this section, the name and location of the node can be configured internally on the HSM200, in the Name in Node and Location in Node sub-sections.
