Delete a Widget
This article will show you how to delete a widget from your dashboard.
On Android:
To delete a widget, long-press on its name until you see a menu. There will then be an option to delete that widget.
https://s3.amazonaws.com/helpscout.net/docs/assets/576175c3903360713dcecf19/images/5b4511cb0428630abc0bea0b/file-spc5j0E6n1.png
On iOS:
To delete a widget, tap its name to bring up a menu, which is where you will see the option to Delete Widget.
