Exporting a Dashboard
This article will show you how to export a dashboard to HomeSeer Mobile.
Editing
We do not recommend editing the JSON data as this may break the import or result in missing data on your dashboard.
On Android:
Requires version 1.1.13
While in the Dashboard section of the app, tap the three-dot menu in the top right corner of the screen. You will see a menu appear, select Import/Export Dashboard. You will then be presented with JSON data. Click Copy to Clipboard to save the data.
We recommend you save this text in a note, email, or other means of saving text.
On iOS:
While in the Dashboard section of the app, tap the three-dot menu in the top right corner of the screen. You will see a menu appear, select Import/Export Dashboard. You will then be presented with JSON data. Click Copy JSON to save the data.
