HS4 Beta 4.1.100.0 (Beta 4.2)
Key
Summary
HS-1253
Connect PSDK Display Priority and Type values to internal data
HS-1336
HS4 plugins that include both a Linux and Windows version do not install the correct version
HS-1295
Issues with navigation on device properties page, navigation rework
HS-798
Changing device category overrides any unsaved changes in device config
HS-1325
Add support to disable device access to an HS device based on the Cloud Access setting
HS-1343
Update PSDK to v1.3.1.0
HS-1332
UI issues on iOS, events pages sometimes fails to load
HS-384
Enabling/Disabling Plugins in FireFox Displays Incorrect Plugin Status
HS-1174
New wizards for setting up system including configuring MyHS
HS-1243
HS4 update through setup does not finish on some Linux systems due to wait for MONO exit
HS-1328
New format for pop-up messages
HS-1279
Floor and Room column names on search are swapped
HS-1273
Restored some HS3 screens like setup
HS-499
Can't use bulk edit to hide SOME devices
HS-1334
JSON call to get events returns all events regardless of user access setting
HS-1333
Upload of camera videos not honoring individual upload settings in setup
HS-1096
HomeTroller Pi Hub Switching Off DHCP in Network Setting Does not work as expected
HS-1104
Plugin registration | Removing the confirmation popup
HS-1229
Root Device Designation format change on Device List View
HS-1269
Reorganize the device settings page
HS-1092
No warning when leaving the features tab with unsaved changes
HS-1175
There is no safety prompt when deleting devices
HS-1094
Add info to the ROOT DEVICE in features tab
HS-1301
Display type pop-up changes
HS-1101
Add a toggle button to hide/show beta plugins on Add plugin page
HS-1216
Sticky Bulk Edit Button/Menu
HS-1310
Show feature status image on features tab
HS-1298
Features page changes to save behavior
HS-749
PostBackProc not called if page doesn't have a .html extension
HS-1264
Float the save button in a bottom bar when off screen
HS-1070
Drop down menus are too small for control use options
HS-1095
Add UP and DOWN arrows to feature priority selection
HS-1233
Pi Hub System Password and default account seems to be messing up
HS-1285
Add the ability to report usage statistics for the Labs features
HS-1338
SweetAlert2: Unknown parameter "buttonStyling"
HS-1329
Add release notes links to setup
HS-1064
HS 4.2 Device Priority Display
HS-1063
HS 4.2 Device Priority Reorder
HS-1284
Add Labs setting to disable feature icon bar in grid view for 4.2
HS-1262
Remove page cards from pages that do not need it
HS-1259
Review and update button colors and uses
HS-1263
Update backup/restore page design
HS-1258
Standardize workflow for adding things to HomeSeer
HS-1260
Standardize view/edit navigation for all things
HS-1299
Change tooltip for display type button on features page
HS-1093
No extra features for this device message on features tab
HS-1321
Use new success popup
HS-1313
Change mouse cursor to grab hand in features tab in device properties
HS-1300
Highlight Important icon
Fixed month of Feb not displaying on energy page
