HS4 Beta 4.2.0.5
Changes
Key
Summary
HS-1400
Feature display order is not saved in device properties
HS-1397
Add an icon next to the event name if the event is not configured
HS-1393
Copy Event does not create unique identifier for triggers
HS-1391
Move bulk edit drop down up to top row to save space
HS-1390
Logout link from top bar menu is not working
HS-1386
Change Installed menu item to Manage for plugins
HS-1385
Log reporting HTML error cannot access member d.location2
HS-1384
When selecting the device trigger "for at least", the pop-up warning dialog flashes to quickly
HS-1382
Use location 1 first option not honored in list view
HS-1381
Events page is referencing fontawesome external site
HS-1354
Add a few other options to bulk edit, no_log,powerfail,last_change,remove category
HS-1353
Make selections in bulk edit match feature names
HS-1283
Implement improvements to plugin (app store) cards
HS-1279
Floor and Room column names on search are swapped
HS-1025
24 hour clock format is no longer available for log
HS-653
Request to change Device View Buttons to Toggle
HS-229
Add device poll button to Devices page
