HS4 Beta Release 4.2.17.4
Installation
NOTE PLEASE READ: This build includes a new feature called Conditional Actions. This allows you to have actions that are executed based on some conditions you specify. Because of this, the saved format of the events has changed. If you decide to go back to a previous version of HS4 you will lose all of your event actions unless you follow the Reverting to a Previous Version instructions below.
Manual Install
  • Windows
    If you need to perform a new install or the update is not available through setup, run the installer:
  • LinuxFor standard Linux tar file, check in setup for an update, or manually update with the TAR file:
  3. An Install Beta pop up appears. Click INSTALL to begin the installation. This may take several minutes to complete.
Windows
Linux
Changes
4.2.17.4
  • On Windows, fixed event log being written to c:\Logs rather than Logs folder in HomeSeer install location.
  • Added a possible fix for the stuck spinner when checking for updates in Setup.
4.2.17.3
Key
Summary
HS-1805
Conditional Actions: legacy plugins conditions not working when action group is moved
HS-1806
Conditional Actions: some events incorrectly show as "Not Configured" after a reboot
HS-1766
DoGlobalSearch is called twice when clicking the search button
HS-1809
Conditional actions with recurring trigger cause excessive log entries
4.2.17.1
Key
Summary
HS-1803
Backup config folder when upgrading to a newer build
HS-1798
Event Group does not need to be written to events.json
HS-1797
Add scripting access to html tags format is: {{run_script_function script proc params wait singleinstance}}
HS-1795
Access to the state object using html tags retrieves the wrong page
HS-1794
Add events access to json interface format is: /JSON?request=getallevents
HS-1783
Sweetalert popups not displayed in group actions and group conditions pages
HS-1777
Avoid refreshing the whole page when a JUI action or trigger is updated or saved
HS-1773
Possible duplicates of strTrigActInfo.UID
HS-1766
HS-1765
404 page when hitting enter on a search from the root page
HS-1708
GetPropertyByType(dev, EProperty.FeatureDisplayType) returns PriorityDisplayType instead of EFeatureDisplayType
HS-1683
Conditional Actions Added to event builder
HS-1664
Editing 2 events in different browser tabs causes event corruption
HS-1499
HSTouch Server Warning "Exception on String Change callback: Value was either too large or too small for an Int32"
HS-1372
Copying a device Adds the word "copy" to loc1 and loc2 values
