HS4 Beta Release 4.2.18.29
Manual Install
Windows
Linux
If you need to perform a new install or the update is not
available through setup, run the installer
For standard Linux tar file, check in setup for an update, or
manually update with the TAR file
  3. An Install Beta pop up appears. Click INSTALL to begin the installation. This may take several minutes to complete.
Windows
Linux
Changes from 4.2.18.5
  • Added support for Reolink cameras include the Reo Duo outdoor dual camera
  • Added some new icons for use with the new ONVIF Events plugin
  • Some minor changes to the camera views button placement
  • Fixed the "Pan Stop" command not working for cameras that support pan/tilt
Changes from 4.2.18.8
  • Fixed camera view not updating
Changes from 4.2.18.15 to 4.2.18.18
Key
Summary
HS-1761
HsEvent is not raised at the end of a backup operation
HS-1857
Add querystring to set grid and list modes
HS-1856
Allow quotes in devices chips searching to search refine search
HS-1787
Shutdown script is running too late in the shutdown process
HS-1767
Add gwebsvrport=80 attribute to settings.ini by default
HS-1853
Added ability to create events triggers and actions from device properties using the new Events tab
HS-1763
fixes to event searching by device/feature, added searches of global actions and conditions, cleaner updates of devices page, added status=## to search on status values,
added querystring to set the viewmode like devices.html?view=grid (list). Added Events tab to device properties to view referenced devices.
HS-1671
Enhance JSON controlbydevicevalue warnings
Added update to plugin status on plugins page without forcing a refresh
Added TLS support to SMTP email sending
Changes from 4.2.18.28 to 4.2.18.29
  • Change devices search to "OR" all tags rather than "AND". This reverts the results to the same as they were in 4.2.18.5
  • Added the ability to add a "AND" tag. When this tag is added the results must include ALL tags
  • Search from the devices search box is now faster
  • Cannot set room/floor for a feature is location1 is set to display first
Changes from 4.2.18.21 to 4.2.18.28
  • Fixed a memory leak causing pages to load slowly
Changes from 4.2.18.21 to 4.2.18.25
  • Cleaned up alignment in the search box on devices page
  • During bulk edit, if the location is changed, or a category is removed, the current selection is cleared
  • Added ability to display the summary of the trigger in the events list
  • Fixed tootips getting stuck on screen for the feature icons in grid view
  • Added "address=" as a search option in the device search box
  • Added some changes to the stepper for trial users to skip MyHS setup
  • Added a default configuration for trial users so the system can tested without any hardware
  • Fixed device filtering so all filters are now required for a match to be true (filters are ANDED)
Changes from 4.2.18.20 to 4.2.18.21
  • Fixed search on devices page so search terms need to all be TRUE for the device to display
  • Fixed bulk edit where checking the ALL checkbox would select devices that were not in the filtered list
Changes from 4.2.18.19 to 4.2.18.20
  • Better syncing of manually entered search terms and location/category dialog settings
  • An empty events list cannot be saved. This should avoid issues where the events could get cleared by accident
  • querystring ?sortby=namedec now works properly
  • HSTouch designer now sees the REODUO camera as 2 cameras so both can be displayed
  • Fixed device feature name incorrect on events tab in device properties
Changes from 4.2.18.18 to 4.2.18.19
  • Fixed device name on events tab in device properties incorrect
  • Added device page query ?showhidden={yes|no}
  • When entering searches on the devices page (chips/tags area) and the entry contains "=", the results are shown without hitting enter, (ie: statue=on)
  • Added a tooltip with the search options
  • Fixed bulk edit operations not executing
