HS4 Beta Release 4.2.19.17
Manual Install
Windows
Linux
Download HS4 Windows
Download HS4 Linux
Changes
This release includes some core changes that support our new Z-Wave Plus Z-Wave plugin. It also includes a security update to Newtonsoft.
For Developers
The Newtonsoft update created some dependency issues and required the following changes.
  • HS4 references an updated pluginsdk dll in bin/pluginsdk_1_5_0. If you update your plugin and wish to reference a newer version of the DLL, reference the one in the folder for the version you need. This reference is in your plugin EXE config file.
  • We are leaving the pluginsdk dll version 1.4.4 in bin/homeseer so existing plugins continue to function properly.
  • HS4 now references the  Newtonsoft dll in bin/homeseer/newtonsoft_13_0_3_27908. Note that developers should NEVER reference this DLL. Continue to reference your own Newtonsoft DLL in your private folder in bin/PLUGIN_NAME.
  • The previous Newtonsoft dll version 12.0.03 is remaining in bin/homeseer as some plugins are referencing this DLL due to a configuration error with the probing privatePath in their config file. Your config file should always look in your private bin folder first for dependent dlls. A proper probing privatePath in your config file looks like this: <probing privatePath="bin/PLUGIN_NAME;bin/homeseer"/>
  • These change ensure that current HS4 installations work normally but allows the HS4 application to reference updated DLL's.
  • We are aware of issues with dependency management and will be reviewing a more robust solution going forward.
HS4 Changes from 4.2.19.16
  • Fixed plugin errors related to Newtonsoft changes
  • Fixed scripting errors due to settings.ini referencing newtonsoft and/or pluginsdk
  • Fixed issue with missing assembly binding statement in EXE config file
HS4 Changes from 4.2.19.5
Key
Summary
Update PluginSDK to v1.5 Release Notes
HS-1187
Events break if the status text is updated
HS-1771
Update Newtonsoft to version 13
HS-1838
If "hide from all views" is checked on a feature, the entire device is hidden
HS-1877
Cannot set feature room or floor if location 1 is set to display first
HS-1882
The script API function Event_info is not returning the correct value for Last_Triggered
HS-1883
Events using a sunset/sunrise trigger with security offset log a warning
HS-1886
Opening a device's settings in a new tab doesn't load
HS-1889
Error when displaying just the feature properties
HS-1895
GetPropertyByType(dev, EProperty.Relationship) returns eRelationship instead of ERelationship
HS-1925
Allow plugins to get and set device/feature version
HS-1927
Querystring with a category is not filtering device list
HS-1932
Location Fields need to be trimmed before saving
HS-1919
Add ability to delete auto discovered cameras
Windows
Linux
