HS4 Beta Release 4.2.19.25
Manual Install
Windows
Linux
Download HS4 Windows
Download HS4 Linux
HS4 Changes from 4.2.19.17 to 4.2.19.25
Key
Summary
HS-1315
Fixed log warning about MyHS not being available
Added some file exclusions from the backup to avoid some log warnings
HS-1819
Fixed backups not running if they were scheduled for 3:00 AM
HS4 Changes from 4.2.19.16 to 4.2.19.17
This release includes some core changes that support our new Z-Wave Plus Z-Wave plugin. It also includes a security update to Newtonsoft.
Key
Summary
HS-1771
HS-1938
Fixed issue with ASPX pages not displaying and plugin links not working
For Developers
Note: These changes were added in Beta 4.2.19.16
The Newtonsoft update created some dependency issues and required the following changes.
  • HS4 references an updated pluginsdk dll in bin/pluginsdk_1_5_0. If you update your plugin and wish to reference a newer version of the DLL, reference the one in the folder for the version you need. This reference is in your plugin EXE config file.
  • We are leaving the pluginsdk dll version 1.4.4 in bin/homeseer so existing plugins continue to function properly.
  • HS4 now references the  Newtonsoft dll in bin/homeseer/newtonsoft_13_0_3_27908. Note that developers should NEVER reference this DLL. Continue to reference your own Newtonsoft DLL in your private folder in bin/PLUGIN_NAME.
  • The previous Newtonsoft dll version 12.0.03 is remaining in bin/homeseer as some plugins are referencing this DLL due to a configuration error with the probing privatePath in their config file. Your config file should always look in your private bin folder first for dependent dlls. A proper probing privatePath in your config file looks like this: <probing privatePath="bin/PLUGIN_NAME;bin/homeseer"/>
  • These change ensure that current HS4 installations work normally but allows the HS4 application to reference updated DLL's.
  • We are aware of issues with dependency management and will be reviewing a more robust solution going forward.
Release 4.2.19.16 includes some core changes that support our new Z-Wave Plus Z-Wave plugin. It also includes a security update to Newtonsoft.
PluginSDK Release Notes for version 1.5
Windows
Linux
