HS4 Beta Release 4.2.21.31
After testing completes, this build will be released as 4.2.22.0.
Manual Install
Windows
Linux
Download HS4 Windows
Download HS4 Linux
HS4 Changes from 4.2.21.25 to 4.2.21.31
Key
Summary
Fixed a problem created with a previous build that caused high CPU usage
HS-2056
Swapped dashboard icons save and settings so save icon aligns with edit icon
HS-2054
Search results that return device links now allow controlling the device from the pop-up dialog.
HS-2045
Fixed pages displaying scriban code when multiple tabs are open
HS-2041
Fixed alignment of status text on dashboard device cards
HS4 Changes from 4.2.21.25 to 4.2.21.28
Key
Summary
HS-2053
Fixed some plugin web pages refreshing every 2 seconds
HS-2052
Events and devices are not written when HS is shut down or started up. This should help avoid event and device file corruption.
HS-2046
Check for updates on startup is delayed by 2 minutes. This is adjustable with the INI setting: gUpdateCheckDelayMinutes
HS-2045
HS-2041
HS4 Changes from 4.2.21.22 to 4.2.21.25
Key
Summary
HS-2044
Error message when a plugin cannot be installed because of old HS version can be confusing
HS-2045
GetUserDashboard error on startup
HS-2046
When HS starts and triggers events based on plugin updates, some event actions may fail if a plugin has not finished starting up
HS-2043
Changed width on dashboard camera cards to use card width
HS-2042
Fixed compact skin not displaying properly
HS-2041
Drop lists are cut off on dashboard device cards
HS4 Changes from 4.2.21.21 to 4.2.21.22
Key
Summary
HS-1964
Fixed feature status changes now honoring setting in setup. Added a separate setting for logging “Sets”.
HS-2038
Clicking on a shop page card displayed a corrupted card.
HS-2039
Dashboard cards did not display controls if the device was an HS3 device with controls on the root device.
HS-2040
The filter bar on the devices page was sometimes missing
HS4 Changes from 4.2.21.19 to 4.2.21.21
Key
Summary
HS-2035
Upgraded masonry code to a more robust package for support of future enhancements, fixed some spacing issues on mobile
HS-2032
Plugins manage page is not notifying when a beta update is available for a released plugin
HS-2030
Removed the 5 plugin limit on the PI-HUB if the flash size was under 32 gb
HS-2029
Dashboard cards no longer truncate status text
HS-1531
If a beta plugin is installed and then is changed to a release but the version does not change, the plugin shows as released and not a beta
HS4 Changes from 4.2.21.18 to 4.2.21.19
Key
Summary
HS-2028
Some plugins are reporting errors at startup and may not be functioning
HS-2027
If a camera card contains the "Controls" button, the button is non-functional
HS-2026
Cameras not displaying on dashboards
HS-2025
Alpha sorted bulk edit menu
HS4 Changes from 4.2.21.15 to 4.2.21.18
Key
Summary
HS-2021
If the sort order is set on the devices page and then a dashboard is displayed, the sort order setting is lost
HS-2020
Update notification bell icon even if page is not refreshed
HS-2019
Add ability to poll devices on a dashboard
HS-2018
Device filters selector missing from devices page
HS-2017
Dashboards do not display properly when using the compact skin
HS-2016
Need setting to make a selected dashboard the first screen to appear when loading the HS4 UI. Setting added to dashboard settings dialog.
HS-2015
Need setting to make Dashboards the first item on the navbar. Setting added to Custom tab in setup.
HS-2009
Battery value should be a separate feature on the thermostat card
HS-2023
Dashboard menu is now alpha sorted.
Removed search box when a dashboard is put into edit mode
HS-1964
Added ability to log feature status changes. Enable in the logs section in setup on the General tab. Check the “no log” checkbox on a device if it is logging too often. Device references in the log entry are now linked to the actual device.
HS4 Changes from 4.2.21.0 to 4.2.21.15
  • Added a new dashboards feature. This is considered version 1 of this feature and more additions will be added in subsequent releases. Documentation is .
Windows
Linux
