HS4 RC2 4.0.9.0
Changes
HS-847,13846,Trial and HS3 to HS4 license registrations not working
HS-845,13836,Registration stepper displays confusing text for step 2 when skipped, moved some settings, web user setup, to stepper
Add the time to setup next to the sunrise/sunset times HS-852
Bad subscription backup time causes a backup every minute HS-849
SupportsConfigDeviceAll has no effect HS-861
Cleaned up events view if no events are defined
When creating a new virtual device, the device properties did not display
Known Issues
  • You can register your HS3 plugins on HS4 with your HS3 plugin license (or a trial license) but you may get a dialog that says "Registration Failed: " with no message. You can safely ignore this message, the plugin did register.
