HS4 Release 4.1.13.0
Key
Summary
HS-1017
Devices pages shows as HTML code and other pages become unusable as well
HS-1003
Only allow Admin accounts to be set with Local
HS-432
SONOS speakers don't show up as "Speak Something" options as in HS4
HS-1117
Cannot filter on category on devices page
HS-1037
Events can be given the same name
HS-1013
Post device's value or status set to webhook (for Node Red)
HS-1069
Device Buttons are removed on HS4 Startup
HS-1045
It is not possible to use decimal values for v4 (virtual) devices for the status graphics
HS-1044
It is not possible to disable the inclusion of the value.
Note that the HS3 option "Include Values" was added and can be checked if the device is an HS3 device.
For HS4 devices the fix will be in 4.1.14.0 and the label can be added in the status/graphics section.
HS-964
Move camera resolution settings out of auto discover area
HS-1035
Change timer on device config updates to less than 1 minute
HS-1038
Adding Category should prompt for input to be consistent with other additions
