HS4 Release 4.1.15.0
Key
Summary
HS-79
GroupViews do not work on Action/Trigger config pages
HS-1169
Dialogue box shows incorrect message when removing a device category.
HS-1138
Changing sub trigger does not call plugin to refresh fields
HS-1155
Can't display 2 plugin device config pages for the same device.
HS-1137
Navigating to any page that starts with LOGIN causes the login prompt to appear
HS-1161
Modify JSON web API getstatus so it returns the root and children when passed a child ref if everything is set to true
HS-1122
ToModernFeature() throwing exception for some HS3 devices
HS-1178
IHSApplication.CAPIGetStatus is not returning the device value
HS-1147
Plugin pages named the same as a HS4 page don't work
HS-1171
Energy page doesn't fully work with HS4 devices
HS-1165
Add a spinner when displaying energy stats
HS-1153
Radio select values are not saved on device config pages
HS-1040
SelectListView dupicated on device config page
HS-1170
Allow update of HS4 on Windows to work through setup as it does on Linux
HS-1173
Energy page stuck on spinner
HS-1156
When sending email only the TO field accepts multiple emails
HS-1166
Add yesterday and last month to energy stats
HS-1159
User access for a feature does not work
