HS4 Release 4.1.16.0
Key
Summary
HS-1157
Event condition issue with non-US short date format
HS-784
HS3 DeviceClass.Code is unavailable and not included in Address as it should be
HS-1150
Add log warning when a plugin Id contains non allowed special characters
HS-1221
When installing a system update on Windows, the countdown screen times out too early
HS-1183
Change Upgrade text in Installer from HS3 Guide Link
HS-1207
Keep MyHS subscription info in sync
HS-1208
Implement IHsController.PluginPropertyGet
HS-1210
Implement GetFeatureByCode and GetDeviceByCode
HS-1213
Non-allowed characters in JUI views
HS-1195
JSON API: controldevicebyvalue and setdevicestatus expect value to be formatted according to regional settings
HS-1108
Rename "Edit Status/Controls" section to "Edit Controls" for HS4 devices
HS-1209
Implement IHsController.PluginPropertySet
HS-1220
HSTouch clients cannot display https images
HS-1198
When displaying a plugin config page the old HS3 navigation links still appear
HS-1151
JS error every time you select a trigger or action
