HS4 Release 4.1.17.0
Key
Summary
HS-1267
Update PSDK to v1.3
HS-1268
References to EEnergyFeatureSubType need to have their namespace specified
HS-1250
Add SendControlForFeatureByString implementation
HS-945
Attempting to perform a backup on an SEL is causing it to crash
HS-1021
"Invalid or error state" trigger not saving correctly
HS-1245
Triggers and Actions don't work for plugins with underscore in their ID
HS-1225
Camera settings won't save the stop url for pan right and pan left
HS-1228
ToModernFeature throws exception on a Z-Wave Luminance feature
HS-1244
Update javascript for new JUI TimeSpanView
HS-1241
Update javascript for new JUI TextAreaView
HS-1236
Allow plugins to display a specific config page for each feature
HS-1234
Update javascript for changes made to the JUI ViewGroup
HS-1255
HS4 Sentry is missing from PI Hub and Linux TAR files
HS-1235
Exception while using scriban plugin_property_get
HS-1239
Google Home users cannot control multiple devices at once
HS-1242
Fix for HS-1195 broke some scripts
HS-787
Controls panel from grid view does not update device status
HS-650
No way to deselect energy devices on select devices dialog on energy page
HS-1200
Add search function in event creation
HS-1218
Modify windows registry on startup to disable windows updates
HS-1251
If the OS shuts down HS, HS Sentry gets shut down also
HS-1219
Display Location 1 First setting does not work in list view
HS-1217
Notify for plugin update when beta is installed
HS-1097
"(leave unchecked for all)" should be changed to "(leave unchecked for default client(s))"
HS-782
HsApplication.DeleteDevice method deletes all associated devices regardless of source type
HS-1226
Change delete button to say delete feature or delete device
HS-1136
IP Hack blocking setting not properly saving in Network settings
HS-1102
Change plugin search text to "Search Plugin List"
