HS4 Release 4.2.0.0
This is a full change list for 4.2
Key
Summary
HS-1359
Status in grid view is not updating
HS-1351
HS4 Registration Stepper step 4 Linux. Create Your Controller System Password does not work properly
HS-1253
Connect PSDK Display Priority and Type values to internal data
HS-1350
Add MyHS account to Users page after MyHs Registration stepper step 2
HS-1344
MyHS login from the MyHS wizard on Pi just spins and never proceeds past step 2
HS-1339
MyHS wizard step 5 fields are not sized correctly
HS-1336
HS4 plugins that include both a Linux and Windows version do not install the correct version
HS-1081
HS4 on the PI HUB needs to be ablet o view log data prier to reboot.
HS-1295
Issues with navigation on device properties page, navigation rework
HS-798
Changing device category overrides any unsaved changes in device config
HS-1121
Additional data is not replaced in events
HS-1356
Problems with POST requests to non registered plugin pages
HS-1367
MyHS camera checkbox setting not saving
HS-1352
GetDeviceWithFeaturesByRef throws exception if features DisplayIndex values are 0
HS-1361
Registering and posting to html pages with query parameters
HS-1325
Add support to disable device access to an HS device based on the Cloud Access setting
HS-1343
Update PSDK to v1.3.1.0
HS-1332
UI issues on iOS
HS-1330
Deleting a feature deletes the whole device
HS-1275
Filters are broken in list view
HS-1335
Can't select non alphanum controls in a "Control Device"event action
HS-1355
Add a warning message about the system restarting when installing a beta
HS-1368
Can't change camera password for auto-detected camera
HS-1375
Colon in ASPX url downloads the web page
HS-1374
For the media card, the player status device was not being displayed
HS-1174
HS 4.2 Setup wizards
HS-749
PostBackProc not called if page doesn't have a .html extension
HS-1348
"Changes you made may not be saved" message when clicking save button on device plugin config tab
HS-1243
HS4 update through setup does not finish on some Linux systems due to wait for MONO exit
HS-1279
Floor and Room column names on search are swapped
HS-499
Can't use bulk edit to hide SOME devices
HS-1334
JSON call to get events returns all events regardless of user access setting
HS-1333
Upload of camera videos not honoring individual upload settings in setup
HS-1096
HomeTroller Pi Hub Switching Off DHCP in Network Setting Does not work as expected
HS-1104
Plugin registration | Removing the confirmation popup
HS-1293
Display priority issues after deleting a feature
HS-1276
Navigation issues when editing a feature
HS-1229
Root Device Designation on Device List View
HS-1292
Modify reference from voice to cloud in settings
HS-1269
Reorganize the device settings page
HS-1092
No warning when leaving the features tab with unsaved changes
HS-1085
New BLLAN devices are added as orphaned features.
HS-1175
There is no safety prompt when deleting devices
HS-1301
Display type pop-up changes
HS-1101
Add a toggle button to hide/show beta plugins on Add plugin page
HS-1216
Sticky Bulk Edit Button/Menu
HS-1314
Root device displayed in features list
HS-1310
Show feature status image on features tab
HS-1298
Features page changes to save behavior
HS-1264
Float the save button in a bottom bar when off screen
HS-1070
Drop down menus are too small for control use options
HS-1095
Add UP and DOWN arrows to feature priority selection
HS-1233
Pi Hub System Password and default account seems to be messing up
HS-1080
Linux Tools doesn't work in Ubutntu
HS-1360
Disabling the Find service from the Labs page is not working
HS-1347
Update startup splash screen for Windows
HS-1364
HS3 devices with no features should not repeat the device name
HS-1259
Review and update button colors and uses
HS-1329
Add release notes links to setup
HS-1284
Add Labs setting to disable feature icon bar in grid view for 4.2
HS-1262
Remove page cards from pages that do not need it
HS-1263
Update backup/restore page design
HS-1258
Standardize workflow for adding things to HomeSeer
HS-1260
Standardize view/edit navigation for all things
HS-1299
Change tooltip for display type button on features page
HS-1093
No extra features for this device message on features tab
HS-1321
Use new success popup
HS-1313
Change mouse cursor to grab hand
HS-1300
Highlight Important icon
