HS4 Release 4.2.13.0
Changes
Key
Summary
HS-1619
Bulk Edit is not applying changes to devices
HS-1265
Restoring a Windows HS4 backup to a HomeTroller Pi does not fully work
HS-1380
Add a "Time Frame-Between" condition to HS4 events.
HS-1644
All new user accounts set to Admin
HS-1585
Add support for TLS 1.2, update email support
HS-1432
Searching for tags does not work as expected
HS-1565
If a slash or double quote is in the device filter, it cannot be removed
HS-1573
When an event runs another event, an option is needed to run them in sequence or in parallel
HS-1598
C# scripting fix errors with the using statement, allow support for //css_ directives
HS-1586
Problems with build configurations
HS-1345
Apostrophes in phrases break the speak event action on Pi hubs
HS-401
Modify the events page to not refresh the entire page on edits
HS-1646
Add a restart system option to windows systems
HS-1433
When setting Hide From Views on a root device, all the features are also hidden
HS-1266
Add status bar for media player card in grid view
HS-884
Tool Tip for Feature behaves incorrectly once status icon changes
HS-1441
When clicking on a device name in grid view, the status in the pop up does not update
HS-1622
No way to scroll text when editing scripts
HS-1580
Default speaker clients do not appear as clients in speaker event actions
HS-1626
Thermostat Card only shows the 3 first buttons for HVAC Mode and Fan mode
HS-1628
When thermostat does not have a FanStatus feature, show the status of the FanModeSet feature instead
HS-1627
Thermostat Card is missing some features in the header
HS-1630
Trigger shows $%0$ instead of the actual suffix
HS-1633
Hide setpoint controls in thermostat card when not valid
HS-1631
Features with a status only range do not show values in a dropdown list in triggers.
HS-1637
Typo on 404 page
HS-1427
Add device name to device icon tooltip in grid view
HS-1655
When editing an event with a device trigger or action, page load is delayed several seconds
