HS4 Release 4.2.15.0
Changes
Key
Summary
HS-1698
WiFi settings do not save in HomeTroller PI-HUB
HS-1694
Backup Save To field won't accept Network drives or paths (mapped or otherwise). Fixed so it will accept a network share such as "\\server". Mapped drive letters are not supported.
HS-1686
Unable to create an event with a condition on an HSM200 luminance value
HS-1701
Events with Device Value Triggers are broken with the latest HS4 build
HS-1709
Cannot select "invalid state" for a device triigger
HS-1695
Unable to raise or lower the setpoint on thermostats
HS-1691
Default settings to enable local backups
HS-1702
Error when speaker client connects
Installing
This can be installed from Setup within HS4. Click on the "Check Update" then install from the Beta section.
For Windows:
If you need to perform a new install or the update is not available through setup, run the installer:
https://homeseer.com/updates4/SetupHS4_4_2_15_0.msi
For standard Linux tar file, check in setup for an update, or manually update with the TAR file:
https://homeseer.com/updates4/linux_4_2_15_0.tar.gz
