HS4 Release 4.2.16.0
Installation
New HS4 Stand Alone Software Systems
  • Windows
    If you need to perform a new install or the update is not available through setup, run the installer:
  • LinuxFor standard Linux tar file, check in setup for an update, or manually update with the TAR file:
  2. Click the INSTALL UPDATE button.
  3. An Install Release pop up appears. Click INSTALL to begin the installation. This may take several minutes to complete.
Changes
Key
Summary
HS-1713
Plugin actions/triggers broken in Chrome/Edge version 105 (works ok on Firefox)
HS-1608
Disabling MyHS prevents local/automatic backups from working
