HS4 Release 4.2.17.0
Installation
Manual Install
  • Windows
    If you need to perform a new install or the update is not available through setup, run the installer:
  • LinuxFor standard Linux tar file, check in setup for an update, or manually update with the TAR file:
  2. Click the INSTALL button.
  3. An Install Release pop up appears. Click INSTALL to begin the installation. This may take several minutes to complete.
Changes
Key
Summary
HS-1775
UI crashes after checking for updates
HS-1769
Auto Cloud Backup setting on backup tools page is not saving
HS-1759
Error when multiple speaker clients disconnect
HS-1756
Cache settings and device config pages for plugins
HS-1754
NavigateButtonView does not work if HS web server not running on default port
HS-1753
Filters with certain characters cannot be removed individually
HS-1751
Users running a beta plugin can update to a non public beta
HS-1747
TimeSpanView inside a GroupView is not processing properly
HS-1746
Running events in order operates in unexpected ways
HS-1744
Search results for devices should include full device name
HS-1743
Search is not including devices referenced in group actions or conditions
HS-1734
Events can be saved with no triggers
HS-1729
Speaker clients are removed from the client list without notifying the plugin
HS-1719
Set dropdown selected value to the value the nearest to the current value.
HS-1707
Enhance error message when installation of a plugin fails.
HS-1539
Rooms and Floors with special characters cannot be selected from the bulk action function
HS-1538
Reorder Bulk Actions
HS-1488
Bulk Edit drop-down menu not displaying correctly
HS-1396
Change note icon when note is not blank
HS-1315
System keeps logging message "unable to perform cloud backup as subscripting information is not available"
HS-612
Modify device/feature search behavior for events - ReferencesDeviceOrFeature never called
Plugin SDK has been updated to version 1.4.3
