HS4 Release 4.2.18.0
Changes
Key
Summary
HS-1813
Log database written to C:\Logs
HS-1809
Conditional actions with recurring trigger cause excessive log entries
HS-1805
Conditional Actions: legacy plugins conditions not working when action group is moved
HS-1803
Backup config folder when upgrading to a newer build
HS-1797
Add scripting access to html tags
HS-1795
Access to the state object using html tags retrieves the wrong page
HS-1794
Add events access to json interface
HS-1793
Logging is not working from scheduler.dll
HS-1783
Sweetalert popups not displayed in group actions and group conditions pages
HS-1777
Avoid refreshing the whole page when a JUI action or trigger is updated or saved
HS-1773
Possible duplicates of strTrigActInfo.UID
HS-1766
DoGlobalSearch is called twice when clicking the search button
HS-1765
404 page when hitting enter on a search from the root page
HS-1708
GetPropertyByType(dev, EProperty.FeatureDisplayType) returns PriorityDisplayType instead of EFeatureDisplayType
HS-1683
Conditional Actions added to events | Blog Post about this feature
HS-1664
Editing 2 events in different browser tabs causes event corruption
HS-1499
HSTouch Server Warning "Exception on String Change callback: Value was either too large or too small for an Int32"
HS-1372
Copying a device Adds the word "copy" to loc1 and loc2 values
Known Issues
  • You might notice missing devices from your device list or device property pages that are not formatted correctly. This error is due to some new logging which is causing an error. You can update to Beta 4.2.18.1 which includes a fix for this. 4.2.18.1 is available from Setup.
Windows
Linux
