HS4 Release 4.2.18.3
Installation
NOTE PLEASE READ: If you are updating to this build from a build older than 4.2.18.0, please read the release notes for 4.2.18.0. first.
Manual Install
  • Windows
    If you need to perform a new install or the update is not available through setup, run the installer:
  • LinuxFor standard Linux tar file, check in setup for an update, or manually update with the TAR file:
  3. An Install Beta pop up appears. Click INSTALL to begin the installation. This may take several minutes to complete.
Windows
Linux
Changes from 4.2.18.0
4.2.18.1
  • Fixes an issue where devices are missing from the grid and list view and some device properties pages display corrupted.
4.2.18.3
  • Fixes an issue where local backups would not run if MyHS is disabled or subscription information could be obtained
  • Fixes an issue where backups could not be configured if MyHS was disabled
