HS4 Release 4.2.20.0
Manual Install
Windows
Linux
Download HS4 Windows
Download HS4 Linux
  3. An Install Beta pop up appears. Click INSTALL to begin the installation. This may take several minutes to complete.
Feature Highlights
This version is required if you are upgrading to our Z-Wave Plus plugin.
Changes from 4.2.19.5
Key
Summary
HS-1914
Add spinner when clicking Save on Plugin Device Config page
HS-1771
Update Newtonsoft to v13
HS-1937
After power failure HS4 Config file gets reset to blank devices and events.
HS-1315
System keeps logging message "unable to perform cloud backup as subscripting information is not available"
HS-1900
Ability to change the plugin ID in a plugin event action
HS-1950
Error reading file(3) error with some plugins
HS-1945
Cloud backups will not run if local backup path is not correct
HS-1880
timer and counter devices created by HS4 aren't added to the device filter cache
HS-1939
Startup window is not listing errors
HS-1943
System logging message about subscription information is not available
HS-1942
Device trigger on value greater than hides value input
HS-1927
Querystring with a category is not filtering device list
HS-1923
First time use stepper moves to incorrect step
HS-1889
Error when displaying just the feature properties
HS-1882
The script API function Event_info is not returning the correct value for Last_Triggered
HS-1838
If "hide from all views" is checked on a feature, the entire device is hidden
HS-1919
Add ability to delete auto discovered cameras
HS-1118
HS4 Is Not Shutting Down ffmpeg after recording
HS-641
Camera Auto-Discover Works Intermittently, cameras disappear from setup
HS-1932
Location Fields need to be trimmed before saving
HS-1930
Users reporting warning in the log about subscription information missing
HS-1925
Allow plugins to get and set device/feature version.
HS-1187
Event Issue When Changing the Status/Graphics Text
HS-1924
RELEASE NOTES button links are broken
HS-1726
Time selector defaults to AM
HS-1883
Events using a sunset/sunrise trigger with security offset log a warning
HS-1886
Opening a device's settings in a new tab doesn't load
HS-1895
GetPropertyByType(dev, EProperty.Relationship) returns eRelationship instead of ERelationship
This build also includes an update plugin SDK version 1.5
PluginSDK Release Notes for version 1.5
For Developers
Note: These changes were added in Beta 4.2.19.16
The Newtonsoft update created some dependency issues and required the following changes.
  • HS4 references an updated pluginsdk dll in bin/homeseer/pluginsdk_1_5_0. If you update your plugin and wish to reference a newer version of the DLL, reference the one in the folder for the version you need. This reference is in your plugin EXE config file.
  • We are leaving the pluginsdk dll version 1.4.4 in bin/homeseer so existing plugins continue to function properly.
  • HS4 now references the  Newtonsoft dll in bin/homeseer/newtonsoft_13_0_3_27908. Note that developers should NEVER reference this DLL. Continue to reference your own Newtonsoft DLL in your private folder in bin/PLUGIN_NAME.
  • The previous Newtonsoft dll version 12.0.03 is remaining in bin/homeseer as some plugins are referencing this DLL due to a configuration error with the probing privatePath in their config file. Your config file should always look in your private bin folder first for dependent dlls. A proper probing privatePath in your config file looks like this: <probing privatePath="bin/PLUGIN_NAME;bin/homeseer"/>
  • These change ensure that current HS4 installations work normally but allows the HS4 application to reference updated DLL's.
  • We are aware of issues with dependency management and will be reviewing a more robust solution going forward.
Windows
Linux
