HS4 Release 4.2.5.0
Changes from 4.2.0.0
Key
Summary
HS-1157
Event condition issue with non-US short date format
HS-1421
Only features with controls appear in the device trigger list
HS-1423
jqLocalFileSelector doesn't work, cannot browser local file system with HS3 plugins
HS-1436
Searching for a device and then clicking on the device link brings up a blank page
HS-1425
Cannot add or remove a category from a device feature
HS-1400
Feature display order is not saved in device properties
HS-1406
Not all features are displayed after a plugin creates a device with features
HS-1446
HS3 plugins that rely on HS to manage the COM port do not have the setting on the plugins page
HS-1447
When creating an event that uses a device trigger, you cannot select a root device as the trigger
HS-1437
Some events with plugin conditions incorrectly show the "Not Configured" icon warning
HS-1414
The remove button on the plugins detail page was not always present
HS-1429
Grid view not displaying device status if device does not have any features
HS-1390
Logout link from top bar menu is not working
HS-1430
Cannot enable camera setting "Save Recordings Locally"
HS-229
(NEW) Add device poll button to Devices page
HS-1382
Use location 1 first option not honored in list view
HS-1404
HS3 plugins on the plugins shop page have incorrect links
HS-1384
When selecting the device trigger "for at least", the pop-up warning dialog flashes to quickly
HS-1385
Log reporting HTML error cannot access member d.location2
HS-1407
4.2.0.0 broke hs.DeviceScriptButton_AddButton
HS-1381
Events page is referencing fontawesome external site
HS-1405
Menus are cut off on new installed plugins page
HS-1283
(NEW) Implement improvements to plugin (app store) cards
HS-1386
Change Installed menu item to Manage for plugins
HS-1279
Floor and Room column names on search are swapped
HS-1393
Copy Event does not create unique identifier for triggers
HS-653
(NEW) Request to change Device View Buttons to Toggle
HS-1391
Move bulk edit drop down up to top row to save space
HS-1397
(NEW) Add an icon next to the event name if the event is not configured
HS-1408
(NEW) Change event device actions so existing actions can be edited
HS-1353
Make selections in bulk edit match feature names
HS-1354
(NEW) Add a few other options to bulk edit, no_log,powerfail,last_change,remove category
HS-1409
(NEW) Change device selector in device triggers and actions so only one drop list is needed
HS-1411
Remove version from plugins shop page
HS-1402
Spelling error in network settings pop message
HS-1025
24 hour clock format is no longer available for log, setting added to Setup
