Manage Associations
Information on using the Z-Wave Plus to Manage Z-Wave Associations
Associations are direct wireless links between Z-Wave devices. All modern devices include a group 1 “Lifeline” association which provides device status updates to the hub. Group 2 associations (if available) allow devices to control each other directly without requiring a hub automation. For example, a water sensor may control a water valve or a motion sensor may control a light switch with a group 2 association.
Steps
Adding an Association
In this example, we’ll add a group 2 association to Mark’s Office Light switch that will also control the Reception Overhead Light switch.
  1. Navigate to Plugins > Z-Wave Plus > Manage Associations.
  2. Use the menu to find and Select a Z-Wave Device and click CONTINUE. A list associations that have already been set for this device will display above. In this example, the Lifeline association has been set for Mark’s Office Light:
  3. In the next step, make sure the Add option is selected and click CONTINUE.
  4. A list of available associations will display. Select Group 2 and click CONTINUE.
  5. The device list will automatically appear. Find the device you wish to associate, check the box next to it and click CONTINUE.
  6. The Start step will display the details about the association. Click START to perform the association.
  7. The Wait step will display details about the operation in progress. This may take a bit of time or may happen instantly.
  8. The Done step displays the completed status of the association. Buttons at the bottom perform this functions:
    • MANAGE ASSOCIATIONS ON ANOTHER DEVICE - Takes you back to step #2 above.
    • ADD/REMOVE ANOTHER ASSOCIATION ON THIS DEVICE - Takes you back to step #3 above for the same device.
    • FINISH - Loads the HS4 Devices page
Removing an Association
In this example, we’ll delete a group 2 association from Mark’s Office Light switch that will also control the Reception Overhead Light switch.
  2. Use the menu to find and Select a Z-Wave Device and click CONTINUE. A list associations that have already been set for this device will display above. In this example, the Lifeline association and Group 2 association have been set for Mark’s Office Light:
  1. In the next step, make sure the Remove option is selected and click CONTINUE.
  2. A list of available associations will display. Select Group 2 and click CONTINUE.
  3. A list of associated devices will display. Check the box for the device(s) you wish to remove the association for, then click outside of this box and click CONTINUE.
  4. The Start step will display the details about the association. Click START to perform the association removal.
  5. The Done step displays the completed status of the association. Buttons at the bottom perform this functions:
