PS100 FAQ
FAQ for the PS100 Z-Wave Presence Sensor
FAQ
  • How effective is PS100 at presence detection?
    Very! PS100 can detect extremely small movements such as a person breathing or even sleeping.
  • How does PS100 compare to typical PIR sensors?
    PS100 detects movement, not infrared light, so it will detect anything that moves (even a fan or vacuum cleaner). Additionally, PS100 will work in warmer environments where PIR sensors become less sensitive.
  • What is the PS100 detection range?
    The maximum range is up to 6 meters (19.6 ft). However, there are 8 different distance ranges within that zone and sensitivity may be adjusted for each range.
  • How accurate is the PS100 range setting?
    Extremely! PS100 uses mmWave precision.
  • Will PS100 detect my pets?
    Yes.
  • Will PS100 detect motion through walls or other obstacles?
    Yes, so range and sensitivity may need to be adjusted to suit certain rooms or environments..
  • How is PS100 powered?
    PS100 works with line-powered USB-C adapters.
  • What can I do with PS100’s RGB LEDs?
    You can create automations in your smart home hub to make the two LEDs glow different colors (independently) when things happen in your home.
  • What PS100 features are available to HomeSeer hub users?
    Upon inclusion, HomeSeer device features are created for presence/motion.
  • Where will PS100 be manufactured?
    Currently, pre-production units are being assembled with parts from the US and from overseas.
  • Can I make my own PS100 enclosure?
    Sure. HomeSeer will make the 3D case design available for users who’d like to make their own.
  • What are PS100’s dimensions?
    Size is 76 x 61 x 22 mm or 2.99 x 2.40 x 0.87 inches
  • When will PS100 be available?
    Second round of Beta units will begin shipping in April 2026.
