Terms and Definitions
Commonly used terms and definitions pertaining to HomeSeer
Glossary
Term
Definition
Use Cases
Also Known As
Action
The end result or purpose for any event is to execute an action or sequence of actions.
Turn a smart product on, increment a counter, speak something, etc.
Condition
A parameter that works in conjunction with a trigger to launch an event. Conditions are true over a period of time.
The day of the week is Wednesday, the time is after 4 pm, Garage Door is open, motion is sensed, etc.
Device
Software entity that is designed to represent a physical smart home product. It may or may not be grouped with Features.
After adding a WD200 to your Z-Wave network, it gets listed as a HomeSeer device under the Devices page.
HomeSeer Device
Event
An action or sequence of actions set into motion by one or more triggers which may also include one or more conditions.
Turn on a light 30 minutes before sunset on weekdays, send an email if a temperature sensor report 80 degrees, etc.
Automations, Scenes, Robots, Routines, Applets, Recipes
Feature
Subset or attribute of a HomeSeer device.
For an HSM200, the features are Motion Sensor, Temp Sensor, Light Sensor, and Color Control.
Child Device
Interface
Hardware device that serves to link a technology (like Z-Wave) to HomeSeer Software
SmartStick+, Z-Net, 2413U, RFXCOM
Controller, USB Stick
Node
Unique identifier for smart product software address.
Z-Wave Node #12
Address
Plugin
Software designed to integrate with HomeSeer software to enhance capabilities or add features.
JowiHUE, EasyTrigger, Harmony Hub
Add-on
Smart Home Hub
A computer running smart home software packaged and marketed as a unique product.
HomeTroller Pi, HomeTroller Plus, HomeTroller Pro
Home Controller, Controller, Smart Hub
Smart Product
Hardware device that's designed to communicate with and/or be controlled by a Smart Home Hub.
HS-WD200+ Dimmer, HS-FLS100+ Sensor
Device
Trigger
Anything that happens in an instant that can launch an event
The time is Sunset, Smart Product turns On, Counter reaches 5
Update
A minor revision or "point" release of software.
HS4 v4.0.0.0 to v4.0.1.0
Upgrade
A major revision or "integer" release of software.
HS3 to HS4
Virtual Device
Software entity that's designed to reflect the status or value or something not necessarily linked to a Smart Product
Occupancy, Daytime/Nighttime, Seasons, Defcon 2
Status Device, State Device
Z-Wave Association
A linkage that causes Z-Wave products to communicate directly between themselves
Associating a Z-Wave motion sensor to a Z-Wave wall switch will turn the switch on (and off) when motion is sensed and then no longer sensed
Scene
Z-Wave Optimization
The process by which a Z-Wave smart product rediscovers its neighbors
After initial setup, running an optimization can help nodes discover the best routes back to your Z-Wave controller. Not to be run on large networks.
Z-Wave Network
The wireless web or mesh created by Z-Wave devices where they can see each other and report back to the Z-Wave Controller.
Z-Wave Networks are managed from Plugins > Z-Wave > Controller Management
Mesh Network
Z-Wave Controller
An Interface specifically for Z-Wave hardware.
SmartStick+, Z-Net, UZB, Aeotec Z-Stick
Interface
Additional Information
