Updating your HomeTroller Plus and Setting the Time Zone
How to update your HomeTroller Plus and set the time zone.
It's important to update your Hub to make sure it has the latest features and security updates.  You'll also need to set the time zone to ensure that timed events based on sunset and sunrise will execute at the right time in your locations.
Be sure to check for updates and install any that are available and set the time zone.
  1. Upon booting, HomeSeer checks for updates. You can initiate this process by either restarting your HomeTroller, or just restarting HS4.
  2. HomeSeer needs to be shut down once the update procedure begins.
  3. Double click on the time in the bottom right of your screen in the system tray and then click Change Time Zone.
