Wall Switch Factory Reset
How to do a manual reset on the HomeSeer Wall Switches
MANUAL RESET - Generally to be used only in the event that the network primary controller is lost or otherwise inoperable.
  1. Turn switch on by tapping the top of the paddle once.
  2. Quickly tap top of the paddle 3 times.
  3. Quickly tap bottom of paddle 3 times.
  4. If light turns off and then on again, switch is reset.  If not, repeat manual reset.
Tap Speed for Reset
The six taps for the reset need to be completed quickly, so that the reset is not initiated by accident. We recommend using two hands to carry out the taps as quickly as possible.
