Adding/Removing Devices
Information on adding and removing devices via Z-Tool+.
Once you have selected the system you wish to Add or Remove a device from go ahead and select the operation you wish to perform. After a message appears that tells you when to activate the Add or Remove function on the device being added then put the device into Program Mode.
https://s3.amazonaws.com/helpscout.net/docs/assets/576175c3903360713dcecf19/images/58a5e117dd8c8e56bfa7c239/file-KXGyZ6Thzb.png
