App Navigation
This article will show you how to navigate through HomeSeer Mobile.
Navigation Tabs
There are four main navigation tabs: Dashboard, Devices, Events, and Cameras. Each one is accessible from the bottom navigation bar or the system menu in Android.
https://s3.amazonaws.com/helpscout.net/docs/assets/576175c3903360713dcecf19/images/5b3fd23a2c7d3a099f2e457c/file-zLWiMvKBJR.jpg
Dashboard
View the widgets you've created to get quick access to your most important devices.
https://s3.amazonaws.com/helpscout.net/docs/assets/576175c3903360713dcecf19/images/5b3fd1d32c7d3a099f2e4576/file-8EP0Z2gIKv.jpg
Devices
Browse a full list of all your devices in HS3 along with their controls and ability to filter, search, and create widgets for your dashboard.
https://s3.amazonaws.com/helpscout.net/docs/assets/576175c3903360713dcecf19/images/5b3fd2df0428630abc0bcc36/file-7ZLyCnvyAV.jpg
Events
Run the events you've created in the HS3 web interface from here. Learn how to create events here.
https://s3.amazonaws.com/helpscout.net/docs/assets/576175c3903360713dcecf19/images/5b3fd3052c7d3a099f2e458a/file-Ese4dG9Bcv.jpg
Cameras
View web cameras you've connected to your HomeSeer system. Learn how to set these up here.
https://s3.amazonaws.com/helpscout.net/docs/assets/576175c3903360713dcecf19/images/5b3fd2692c7d3a099f2e4580/file-XQMrmDg0LK.jpg
Menu Navigation
Android
Swipe from the left edge of the screen to view these options and select them for quick navigation. This menu is accessible from any screen.
https://s3.amazonaws.com/helpscout.net/docs/assets/576175c3903360713dcecf19/images/5b3fd2600428630abc0bcc2c/file-Q7Mzs9nuDm.jpg
iOS
IOS does not offer a menu for navigation, you may use the icons at the bottom of the screen.
