EventExists (Event_Info_Group)
Purpose
This function checks if a given events exists in HomeSeer's event list.
Parameters
Parameter: name
Type: string
Description: This is the name of the event.  The name is not case-sensitive.
Returns
Return value: event index
Type: boolean
Description: This returns TRUE if the given event exists and FALSE if it doesn't.
Example
Visual Basic
sub main()
	if hs.EventExists("evening") then
		hs.speak "The evening event exists",TRUE
	else
		hs.speak "The evening event does not exist",TRUE
	end if
end sub
