GetLastEvent (Event_Info_Group)
Purpose
This function returns the name of the last event that was triggered.  This can be used in a script to detect which event the script was executed from.
Parameters
None
Returns
Return value: last event
Type: string
Example
Visual Basic
sub main()
	dim t
	t = hs.GetLastEvent
	msgbox "This script is run from the event: " & t
end sub
