GetLog_Date
Purpose
This function retrieves entries from the system log database and returns them as an array of LogEntry structures.  Use this function when you need to only filter log entries by date.
Parameters
Parameter: StartDate
Type: Date/Time
Description: This is the starting date for the log entries that you want retrieved.  If you do not care about a starting date, use Date.MinValue
Parameter: EndDate
Type: Date/Time
Description: This is the ending (latest) date for the log entries that you want retrieved.  If you do not care about an ending date, use Date.MaxValue
Returns
Return value: LogEntry
Type: Array of Structure LogEntry
Description: See LogEntry Structure.
Example
Visual Basic
    Function GetLog_Date(ByVal StartDate As Date, ByVal EndDate As Date) As LogEntry()
This example retrieves all log entries from a week ago to today:
Visual Basic
Dim Logs() As HomeSeerAPI.LogEntry
	Logs = hs.GetLog_Date(Now.AddDays(-7), Now)
	If Logs IsNot Nothing AndAlso Logs.Count > 0 Then
    hs.WriteLog("Info", Logs.Count.ToString & " log entries retrieved, and this just added another!")
End If
