Skip to main content
Skip table of contents
HS4 Beta Release 4.2.22.29
After testing completes, this build will be released as 4.2.23.0.
As with all Beta releases, make sure you back up your system before installing this Beta!
Manual Install
Windows
Linux
Download HS4 Windows
Download HS4 Linux
HS4 Changes from 4.2.22.27 to 4.2.22.29
  • Added ability to set card format defaults to dashboard settings
  • In Fixed Resizable layout you could change the edit dialog
  • The arrows are removed from the edit bar in fixed resizable layout since the cards are manually positioned
  • The new dashboard dialog did not appear when selected from the dashboards menu
  • Changed the “Save” dashboard icon to an “Exit” icon since the dashboard is not actually being saved
  • Updates to the device cards per user dcorsus (for video playing)
  • Show Last Change on device card can now be disabled
  • Fixed apostrophe in dashboard name not allowing dashboard to be displayed
  • Forecast card now auto updates every hour
  • Added edit menu for Row-Col layout
  • Added a note about changing layouts and losing card order
  • Fixed an error message when selecting a dashboard that does not exist
  • Fixed typos in bulk edit menu
HS4 Changes from 4.2.22.4 to 4.2.22.27
New Feature
See the documentation related to the new dashboard features here.
Dashboards have been expanded to support custom dashboard cards. Custom cards may be provided by HomeSeer or third parties. New features include:
  • Multi feature card: display and control features from multiple devices
  • Status Icon card: Display just the status icon for a feature and control with a toggle
  • Status Text card: Display the status of a feature
  • Forecast Card: Display a 5 day forecast, uses the longitued and latitude that is set in HS for weather data
  • Text Card: Displays just text, useful for tagging groups of cards
  • Button Card: Display one or more buttons and assign an action to the button such as displaying another dashboard or running an event action
  • Notifications Card: Displays a list of notifications
  • Gauge Card: Displays a gauge that can be associated with a feature to display its value
New layouts
  • 4 layouts are available, row/col, masonry, masonry resizable, fixed resizable. Resizable layouts are new and allows for resizing cards. Fixed allows cards to placed at fixed locations and is usable for dedicated display such as a tablet.
Customizable Cards
  • All cards now have more customizable settings such as font sizes, font colors, background colors, background images, and more.
Key
Summary
HS-2068
Added support for custom dashboard cards and more dashboard display options
HS-931
On Linux, events scheduled to run at midnight would run multiple times
HS-1837
If feature one in a device is set as important and feature two is set as hidden, not last change time is displayed in the grid view
HS-2057
Allow adding device last change to device dashboard card
HS-2075
Add media folder to backups
HS-2080
On Linux HSSentry is not disabled when HS is shut down from the tools menu or an update
HS-2092
Allow configuration for WIFI on BPI board with updated Armbian OS (G8 units)
HS-2101
If a control pair label contains a control char, HSTouch may not display data properly
HS-2102
Web server requests getting corrupted causing broken or missing pages
HS-2103
Changes to the HSTouch speaker client user/pass in the setup are not honored
Windows
Linux
JavaScript errors detected
Please note, these errors can depend on your browser setup.
If this problem persists, please contact our support.
