HS4 Beta Release 4.2.22.66
After testing completes, this build will be released as 4.2.23.0.
As with all Beta releases, make sure you back up your system before installing this Beta!
Manual Install
Windows | Linux |
If you need to perform a new install or the update is not available through setup, run the installer | For standard Linux tar file, check in setup for an update, or manually update with the TAR file |
Navigate to Setup > General and click the CHECK UPDATE button.
Click the INSTALL BETA button.
An Install Beta pop up appears. Click INSTALL to begin the installation. This may take several minutes to complete. Your controller or computer will restart after the installation completes.
HS4 Changes from 4.2.22.65 to 4.2.22.66
More fixes for errors with HS3 plugins
HS4 Changes from 4.2.22.64 to 4.2.22.65
Fixed errors with HS3 plugins
HS4 Changes from 4.2.22.61 to 4.2.22.64
Fixed issues with some plugins not loading or settings not displaying
Added the ability for dashboard screens to stay active if not interacted with
HS4 Changes from 4.2.22.59 to 4.2.22.61
Fixed device cards not updating device status
On button card, fixed the ability to set the button label text size and removed the CSS that kept the label all caps
Fixed an issue where resizing a card and then editing its setting, lost the resize
Fixed the “all on/off” button not displaying on multi-feature card
HS4 Changes from 4.2.22.58 to 4.2.22.59
Fixed errors with HS3 plugins either not loading or displaying an error when used
Fixed device card not honoring new order of features after editing the card
HS4 Changes from 4.2.22.41 to 4.2.22.58
New Add Card dialog
When copying a device card, last change was not copied
Fixed issues with navbar menus displaying under cards
Pulled out common code from cards to simplify them, card_text to be used as a base for new cards
Merged in changes required for updated MyHS features
Status text card can now display status text or device value and display device last change, added bold option to text
Added dashboards to user access settings in setup
Added ability to share dashboards with other users
Cleaned up display of multi feature card
Cards auto size properly when changing dashboard display mode
Fixed layout issues when card HTML is updated after page is loaded
Card updates optimized with less callbacks to HS
Changes to button card for use with touch devices
HS4 Changes from 4.2.22.37 to 4.2.22.41
Added text color and background color to button card
Added button to select droplist on feature card
Added bold and suffix text to value on button card
Fixed notification card so it now adds the summary text, added bold to notification text
Fixed issues with multiple feature cards on the same dashboard, added padding in case a scrollbar appears, added background color to title, title no longer scrolls
Gauge card can now reference any feature
Changed background of pop-up edit to blue, text white
Changed exit edit mode icon on navbar to RED to indicate that edit mode is active
Added + icon at lower right of screen to easily add cards
Added custom title to single device status card to override device name
Added “Open URL” action to button card
Added new iframe card to display a web site in an iframe, thanks to ksum for donating his work on the card
HS4 Changes from 4.2.22.32 to 4.2.22.37
Added multiselect for feature selector on multifeature card
Added text color and bold to button card
Added text bold and update interval setting for text card (in case text is a script)
Added device selector to thermostat card
Features on device now use drag/drop to reorder features displayed
HS backups were including an old html.zip file, if it existed, this old file is now removed
Fixed error if a feature was added twice to the multifeature card
Forecast card now includes correct coordinates
HS4 Changes from 4.2.22.29 to 4.2.22.32
Requested changes to how Windows updates are disabled
Fixed some formatting of features on the multi feature card
Fixed thermostat card now allows for adding missing features
Feature name can be hidden on the multi feature card, fixed setting that controls display of device name, text alignment changes
Added icon and ability to add status only features to multi feature card. You can now disable the “All” toggle
HS-2094 Fix for HSEvent not being called for some bulk actions
HS-2064 Fix "Auto Discover Known Camera Types" setting turning off after HS4 restart.
HS-1904 Keep current color when opening a color picker from the devices page.
Added background image and size settings to button card
Fixed location text (size and location) not copied when saving display settings to all cards
Added parse_text function to text card to allow the display of scriban code to the Text card
Fixed "show last change" setting not saving
Changed status text and status image cards to update divs when status changes (as opposed to entire card)
HS4 Changes from 4.2.22.27 to 4.2.22.29
Added ability to set card format defaults to dashboard settings
In Fixed Resizable layout you could change the edit dialog
The arrows are removed from the edit bar in fixed resizable layout since the cards are manually positioned
The new dashboard dialog did not appear when selected from the dashboards menu
Changed the “Save” dashboard icon to an “Exit” icon since the dashboard is not actually being saved
Updates to the device cards per user dcorsus (for video playing)
Show Last Change on device card can now be disabled
Fixed apostrophe in dashboard name not allowing dashboard to be displayed
Forecast card now auto updates every hour
Added edit menu for Row-Col layout
Added a note about changing layouts and losing card order
Fixed an error message when selecting a dashboard that does not exist
Fixed typos in bulk edit menu
HS4 Changes from 4.2.22.4 to 4.2.22.27
New Feature
See the documentation related to the new dashboard features here.
Dashboards have been expanded to support custom dashboard cards. Custom cards may be provided by HomeSeer or third parties. New features include:
Multi feature card: display and control features from multiple devices
Status Icon card: Display just the status icon for a feature and control with a toggle
Status Text card: Display the status of a feature
Forecast Card: Display a 5 day forecast, uses the longitued and latitude that is set in HS for weather data
Text Card: Displays just text, useful for tagging groups of cards
Button Card: Display one or more buttons and assign an action to the button such as displaying another dashboard or running an event action
Notifications Card: Displays a list of notifications
Gauge Card: Displays a gauge that can be associated with a feature to display its value
New layouts
4 layouts are available, row/col, masonry, masonry resizable, fixed resizable. Resizable layouts are new and allows for resizing cards. Fixed allows cards to placed at fixed locations and is usable for dedicated display such as a tablet.
Customizable Cards
All cards now have more customizable settings such as font sizes, font colors, background colors, background images, and more.
Key | Summary |
HS-2068 | Added support for custom dashboard cards and more dashboard display options |
HS-931 | On Linux, events scheduled to run at midnight would run multiple times |
HS-1837 | If feature one in a device is set as important and feature two is set as hidden, not last change time is displayed in the grid view |
HS-2057 | Allow adding device last change to device dashboard card |
HS-2075 | Add media folder to backups |
HS-2080 | On Linux HSSentry is not disabled when HS is shut down from the tools menu or an update |
HS-2092 | Allow configuration for WIFI on BPI board with updated Armbian OS (G8 units) |
HS-2101 | If a control pair label contains a control char, HSTouch may not display data properly |
HS-2102 | Web server requests getting corrupted causing broken or missing pages |
HS-2103 | Changes to the HSTouch speaker client user/pass in the setup are not honored |
Windows
- Uninstall the beta. Do not remove HS4 settings and temporary files.
- Install the previous version.
- Launch HS4 and navigate to Setup > General and click Edit Config
- Select the config file that was created when the beta was installed. The name will contain _before_4.2.x.x.json
- Check your events to confirm they're all there and the actions are correct
Linux
- Navigate to Setup > General and click REINSTALL UPDATE
- Once installation is complete, navigate to Setup > General and click Edit Config
