Importing Z-Wave Devices
Importing devices will pull the Z-Wave devices from your interface into your Devices page. This can be useful if your system stops working and you do not have a backup, or if you are using an Aeon Labs Z-Stick to add devices that live far away from your HomeSeer system.
Accessing the Legacy Z-Wave menu
If you have the Z-Wave UI plugin installed, the option to import devices will not be immediately available. Use the steps below to access it.
  1. Navigate to Plugins > Z-Wave > Settings
  2. Click the Show Legacy Z-Wave Menu slider, then click Save.
  3. It is now recommended to restart HS4 by shutting down the program window in Windows or by using Tools > System > Restart System on Linux.
  4. You will now have access to the Controller Management page and can start the instructions below.
  1. From the web interface, use the pull down menus to navigate to Plugins > Z-Wave > Controller Management.
  2. Locate the Z-Wave Interfaces area and expand the section of your Z-Wave Controller. Open the Actions drop-down menu and choose Import Node Info from Controller and Scan Devices.
  3. Click Start, your HomeTroller will now import your device information from your Z-Wave interface. When done, you will receive an acknowledgement such as “Finished with Z-Wave device synchronization”. Your Z-Wave devices may now be monitored and controlled from HomeSeer!
Notes
  • Because battery-powered devices are not always away, they may not work with this process. Any devices which do not get added from the import should be removed and re-added to the network.
