Mono 3.2.8 on SEL
See here if your SEL is still on mono 3.2.8 and you are trying to get to mono 5.
SSH ONLY and on Systems with 3.2.8 where original Mono 5 SEL script is not working
Backup your system before making any changes in the Linux OS.
Login with root
Use the command cd /etc/apt/lists/sources.d
Next, use nano sources.list to find out which version of Lubuntu is installed. It will be repeated toward the end of each source line (usually trusty) then exit
EXAMPLE (oneiric repeats)
https://s3.amazonaws.com/helpscout.net/docs/assets/576175c3903360713dcecf19/images/5d5af6632c7d3a7920be39db/file-7MpF65dAeC.png
Use cd /etc/apt/lists/sourceslist.d and there should be a mono sources list file here.
Use nano sourceslist.d, and it should contain something like "deb http://download.mono-project.com/repo/ubuntu VERSION main", where VERSION could be wheezy, trusty, bionic, oneiric, or something else.
Make sure that VERSION matches what was repeated in the sources.list and add -stable
EXAMPLE: "deb http://download.mono-project.com/repo/ubuntu trusty-stable main"
Save and Exit.
Now run apt-get update and then apt-get upgrade
If the upgrade is not working or completing, you can run apt-get dist-upgrade. The overall upgrade should take 5-10 minutes. You will see mono 5.XX in the file names as it unpacks and installs.
You may have to fix some broken events afterward, as this is a big upgrade.
