Replacement Variables
Documentation on using replacement variables in HS4Touch. See Date & Time Variables for detailed information on date and time replacement variables.
Replacement variables allow you to display and or use content that is dynamic in HS4. This feature is not to be confused with the new variable feature that is described in the properties section. Replacement variables can be used in the text property of an element, the RSS feed properties and the script action.
Syntax
Replacement variables are inserted into text with [] like: "[$BATTERY]"
Variable
Value
$BATTERY
Battery level of client
$LOCATION1
Current location label
$LOCATION2
Current location 2 label
$LONGITUDE
Longitude value as set in HomeSeer
$LATTITUDE
Lattitude value as set in HomeSeer
$WEATHERAPIKEY
The weather key as set in HomeSeer
$ELEMENT
Returns the text of a label or trackbar element, format is $ELEMENT=SCREEN_NAME->ELEMENT_NAME
$RSS
Replace with RSS item, format is $RSS=URL->TABLE->ITEM->ROW
$REGEXREPLACE
Uses regular expression to replace text in an input string, format is $REGEXREPLACE=INPUT_STRING->PATTERN->REPLACEMENT_STRING
$REGEXMATCH
Match the input string using a regular expression, format is $REGEXMATCH=INPUT_STRING->(PATTERN)
$DATETIME
If no parameter returns the date and time in the default system format, otherwise formats the time as specified. Format is $DATETIME=FORMAT
$TIME
If no parameter returns the time in the default system format, otherwise formats the time as specified. Format is $DATETIME=FORMAT | See Date & Time Variables for more information
$DATE
If no parameter returns the date in the default system format, otherwise formats the time as specified. Format is $DATETIME=FORMAT | See Date & Time Variables for more information
$SCRIPT
Sends and runs a script in HomeSeer and returns the result, format is $SCRIPT=SCRIPT_TEXT
The script text is normally the name of script file, but it could also start with an & and be an immediate script statement
$LASTCHANGE
New for HS4Touch. This returns the date/time the device last changed. Format is $LASTCHANGE=DEVICE_REF_NUMBER
Any variable name
New for HS4Touch. A variable name in the format #NAME will be replaced with the value of the variable. See the Element Properties section for information about variables.
